I'm currently using RoboHelp 9. We are considering using WebHelp format to
publish our Help on our website.
Will Google index the content? If not, will a newer version of RoboHelp
provide this functionality?
Thank you,
<http://www.magicsoftware.com/>[image: email_sig]
Debbie Sarig
*Documentation Manager, *
*Magic xpa Application Platform & Magic xpi Integration Platform *| Magic
Software Enterprises Ltd.
Tel. +972-3-5389277 | Fax. +972-3-5389333
Debbie_Sarig@magicsoftware.com <mkenig@magicsoftware.com> |
www.magicsoftware.com <http://www.magicsoftware.com/?utm_source=email> |
DISCLAIMER. Information in this message and its attachments may be
privileged or confidential. It is for the exclusive use of the intended
recipient(s).
If you are not one of the intended recipients, you are hereby informed that
any use, disclosure, distribution, and/or copying of this information is
strictly prohibited.
If you receive this message in error, please notify the sender immediately
and delete all copies of this message. We recommend that you scan your
incoming Emails.
We cannot accept responsibility for any transmitted viruses.
Google will crawl and index the URLs. You need to submit them at https://www.google.com/webmasters/tools/submit-url?pli=1
Not only google but you can submit the URLs in the same way to other search engines also.
Thanks and Regards,
Surbhi Maheshwari
Be aware that Rh9 may have compatibility issues with the latest browsers. There are posts to confirm that on these forums.
Google will index the pages, but it may not be able to find all the available pages, regardless of RH version and output type. This happens because the crawler won't execute the scripts required to view the Table of Contents, Index, etc. So only the pages that the crawler can find links to will be indexed. These typically are files that are linked to from other indexed locations such as your website.
If you want to have Google, Bing and others completely index your help system, you will have to provide a sitemap. Your developers or web admins should be able to create a sitemap for your help. Or you can opt for my paid solution: http://www.helpessentials.com/downloads/sitemap-generator-for-robohelp/
