How to write out a log file?
Enthusiast ,
Oct 08, 2015 Oct 08, 2015
I have this function below and I tried to write the result of query to log file but it failed every time I ran. the CFLog tag as third line from the bottom. Any suggestion is much appreciated.
<cffunction name="getCommonSpotPages" access="public" returnType="query">
  <cfset var qryCSPages = queryNew("")>
  <cftry>
  <cfquery name="qryCSPages" datasource="#application.sitemap.sDSN#">
  select p.ID, s.subsiteURL, p.filename, p.DateContentLastModified, u.publicFileName, p.uploaded as bIsUploaded, s.uploadURL,
  (select fieldValue from data_fieldValue dfv where p.ID = dfv.pageID and dfv.fieldID = #application.sitemap.nPriorityFieldID# and dfv.versionState = 2 ) as nPriority,
  (select fieldValue from data_fieldValue dfv where p.ID = dfv.pageID and dfv.fieldID = #application.sitemap.sFrequencyFieldID# and dfv.versionState = 2 ) as sFrequency
  from SitePages p
  join SubSites s
  on p.SubSiteID = s.id
  left join UploadedDocs u
  on p.id = u.pageID
  where (p.expDate is null
  OR p.expDate > getdate())
  and p.pageType = 0 <!--- uploaded documents and content pages only --->
  and p.approvalStatus <> 1 <!--- // exclude inactive pages --->
  and s.siteState <> 0 <!--- // exclude inactive subsites --->
  and s.subsiteURL not like '%training%' <!--- specify all pages inside of the subsite to be exlcuded from the sitemap --->
  and s.ID not in (<cfqueryparam value="#application.sitemap.lstExcludeSubsites#" cfsqltype="CF_SQL_INTEGER" list="yes" /> ) <!--- // exclude particular subsites --->
  order by p.ID desc
  </cfquery>
  <cfcatch><cfdump var="#cfcatch#"></cfcatch>
  </cftry>
  <cflog text="#qryCSPages#" type="Information" file="queryPages">
  <cfreturn qryCsPages>
</cffunction>
492
LEGEND , Oct 08, 2015 Oct 08, 2015
All the tmpResult.sql does is print the SQL that was run from within the query.
You cannot tell CF where to save logs.  They are available at [DRIVE]/cfusion/logs - go there and look for your log.  It can also be accessed via CFAdmin, under DEBUGGING AND LOGGING.
HTH,
^_^
You are sending a query object (complex) to a log as a string (simple).  If you REALLY want all of that information in a log file (if it's a lot of data, I wouldn't), you have to loop the query (if more than one record is returned) and spell out each column for each iteration.
HTH,
^_^
EX
<cfoutput query="qryCSPages">
<cflog text="#ID#: #subsiteURL# - #filename# - #DateContentLastModified# - #publicFileName# - #blsUploaded# - #uploadURL#." type="information" file="querypages" />
</cfoutput>
Enthusiast ,
I've modified the query with a result attribute and log the SQL property as followed but it's still not generating any log. By the way, is there a way to specify where the log file will be created? I do a search for queryPages and nothing was found.
<cflog text="#tmpResult.SQL#" type="Information" file="queryPages">
HTH,
^_^
Enthusiast ,
Thanks!  I found the log.
Advocate ,
If you want more control of your logs (I highly recommend this for all production applications) then learn up on log4j -- this is what cflog uses underneath the covers. I've learned over time that proper and abundant logging is as important as proper and abundant testing for supporting a system.
Documentation
