to anyone whom can help:
this is a lesson I'm doing for a class except the tutorial doesn't cover the response to this scenario. My score disappears once the game is in execution mode. I've seen forms suggesting the placement of a .embed code (not specific where) I've also seen a suggestion to change font which i've done and nothing has happened. I don't want to disrupt the code from the lesson to much so any suggestions to what I may be missing I appreciate.
thank you.
//Setting up the game variables
userChoice = "none";
userComp = "none";
//Setting up score variables
Wins = 0;
Losses = 0;
Draws = 0;
Tries = 0;
//control variable
control = true;
//Initial hideLogos call
hideLogos();
function hideLogos()
//Hiding our logos
this.StatWin._visible = false;
this.statLose._visible = false;
this.statDraw._visible = false;
//Choose functions
function choose(newChoice)
//If we have control, run the game
if (control)
hideLogos();
userChoice = newChoice;
trace("You've have selected " + userChoice);
rndChoice = Math.ceil(Math.random() * 3);
//trace ("Random number : " + rndChoice) ;
switch (rndChoice)
case 1 :
compChoice = "Rock";
break;
case 2 :
compChoice = "Zors";
break;
case 3 :
compChoice = "Paper";
break;
trace("Computer selected" + compChoice);
Object(this).scarecrowUser.gotoAndPlay(userChoice);
Object(this).scarecrowComp.gotoAndPlay(compChoice);
control = false;
function gameLogic()
if (!control)
if ((userChoice == "Rock" && compChoice == "Zors") || (userChoice == "Zors" && compChoice == "Paper") || (userChoice == "Paper" && compChoice == "Rock"))
//Result is victory
trace("You've won!");
this.StatWin._visible = true;
wins++;
else if (userChoice == compChoice)
//Result is draw
trace("it's a draw");
Object(this).statDraw._visible = true;
draws++;
else
//Result is loss
trace("you've lost :(");
Object(this).statLose._visible = true;
losses++;
tries++;
control = true;
//Functions for the buttons
Object(this).btnRock.onPress = function()
choose("Rock");
Object(this).btnPaper.onPress = function()
choose("Paper");
Object(this).btnZors.onPress = function()
choose("Zors");
correct the "visible" code: statLose.visible = true; without underscore.
I tried pulling the underscore but unfortunately it still did not work. There was another similar complaint where they changed the font and they were good. I suspect it has something to do with Flash and the imbed radio button.
First thing there's a lot of "visible" code needs a correction. you have to make sure that you've corrected all..
Regarding the font you have to make sure that you've done the following steps correctly:
1- Embed the font inside the flash movie library (click the embed button next to font style field, in the Font Embedding window > Character ranges > select "All".
2- Use this code for all the text fields you have on the stage "textField_name.embedFonts = true;"
One more thing, it's better to add an "as linkage" for the font you've embedded. (from the library select the font and double click on the "Linkage" area then type the font name as a linkage).
Think I very much for info this will take sometime to break down and understand I'll keep you posted.
Sent from my iPhone
This is a simple tutorial on YouTube for Dynamic TextField it'll help if you like to watch it.
https://www.youtube.com/watch?v=LmSibzZbLNY
Regards.
After further review with a friend that has some coding experienced she
broke down for me what you were trying to explain to me as far as
correcting the code I was working with at this point I'm going to reference
the video you sent and also an email in regards to font and property use;
Some links that may help:
http://www.adobe.com/devnet/archive/flash/quickstart/embedding_fonts.html
http://www.adobe.com/devnet/flash/articles/avoiding-mistakes-text.html
Thank you for using Picture and Video Messaging by U.S. Cellular. See
www.uscellular.com for info.
I'm actually a beginner and it appears that the font was not setup properly
(as you were explaining as well) which forces me to be clueless. There
were a lot of things my friend pointed out that I had no idea as far as how
the code was calling on the font and how my code was setup… I'm going to
try and work on this a little at a time and this may be a while but I
really appreciate the help and if I am able to fix this I will respond to
my ticket in which you've been helping me.
Thank you
You're welcome & good luck.
As I see in the screenshot, the score text field has no instance name and in your code you're using trace only trace("You've won!");.. that will not do anything to the score text field it'll only show you the result in the Flash output window! if I am not wrong you have to give an instance name for each text field you want to show your messages through it.. after that use the text fields names in the code to fill the text ( text_instance.text = "You've won!"; ) instead of trace("You've won!");.. plus the previews steps for the font.
