, Line 1, Column 1 | Warning: 5002: The frame scripts of the symbol 'Options' have been ignored because a compiled clip contains a definition for Options. To override the Options definition, place a custom class file within your classpath. |
After I've deleted ALL swf's and swc's in the same folder there's no warning. Then after I've published swf and swc again the warning pops up again....It started with Flash CC. Never happened when I was using Flash CS4
you must have a compiled clip with the Options class defined and you also have code on a movieclip timeline that has its class = Options. it doesn't make sense to have precompiled code AND code that's compiled upon publication.
you need to remove one of those two things, the frame script or the compiled clip.
Thanks, however my knowledge of actionscript is too limited even to understand your answer. I'm not a coder. The files work even with the warning, so I'll just remove the .swf and .swc before publishing.
Thanks anyway!
you're welcome.
