Native Mobile App not working ?
Oct 14, 2015 Oct 14, 2015
Hi i'm trying to generate native mobile app using robohelp i defined all requirement as i think here is:
phonegap sdk : C:\Users\admin\AppData\Roaming\npm ; //not sure if this correct
android sdk : D:\sdk\android-sdk
jdk : C:\Program Files\Java\jdk1.8.0_05
ant : D:\sdk\apache-ant-1.9.5-bin\apache-ant-1.9.5
i got error message "verify jdk /ant paths and refer to out put log" here is my output log
C:\Users\admin\Desktop\apk>android update project --name "NewProject" --target 1 --path .
'C:\Windows\system32\java.exe' is not recognized as an internal or external command,
operable program or batch file.
ERROR: SWT folder '' does not exist.
Please set ANDROID_SWT to point to the folder containing swt.jar for your platform.
Building App NewProject...
C:\Users\admin\Desktop\apk>ant debug
Buildfile: C:\Users\admin\Desktop\apk\build.xml
-set-mode-check:
-set-debug-files:
-check-env:
[checkenv] Android SDK Tools Revision 24.4.0
[checkenv] Installed at D:\sdk\android-sdk
-setup:
     [echo] Project Name: NewProject
  [gettype] Project Type: Application
-set-debug-mode:
-debug-obfuscation-check:
-pre-build:
-build-setup:
[getbuildtools] Using latest Build Tools: 23.0.1
     [echo] Resolving Build Target for NewProject...
[gettarget] Project Target:   Android 6.0
[gettarget] API level:        23
     [echo] ----------
     [echo] Creating output directories if needed...
    [mkdir] Created dir: C:\Users\admin\Desktop\apk\bin\rsObj
    [mkdir] Created dir: C:\Users\admin\Desktop\apk\bin\rsLibs
     [echo] ----------
     [echo] Resolving Dependencies for NewProject...
[dependency] Library dependencies:
[dependency] No Libraries
[dependency]
[dependency] ------------------
     [echo] ----------
     [echo] Building Libraries with 'debug'...
   [subant] No sub-builds to iterate on
-code-gen:
[mergemanifest] Found Deleted Target File
[mergemanifest] Merging AndroidManifest files into one.
[mergemanifest] Manifest merger disabled. Using project manifest only.
     [echo] Handling aidl files...
     [aidl] No AIDL files to compile.
     [echo] ----------
     [echo] Handling RenderScript files...
     [echo] ----------
     [echo] Handling Resources...
     [aapt] Found Deleted Target File
     [aapt] Generating resource IDs...
     [echo] ----------
     [echo] Handling BuildConfig class...
[buildconfig] Generating BuildConfig class.
-pre-compile:
-compile:
    [javac] Compiling 3 source files to C:\Users\admin\Desktop\apk\bin\classes
    [javac] warning: [options] source value 1.5 is obsolete and will be removed in a future release
    [javac] warning: [options] target value 1.5 is obsolete and will be removed in a future release
    [javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
    [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:3: error: package org.apache.cordova does not exist
    [javac] import org.apache.cordova.DroidGap;
    [javac]                          ^
    [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:6: error: cannot find symbol
    [javac] public class DefaultActivity extends DroidGap
    [javac]                                      ^
    [javac]   symbol: class DroidGap
    [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:9: error: method does not override or implement a method from a supertype
    [javac]     @Override
    [javac]     ^
    [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:12: error: cannot find symbol
    [javac]         super.onCreate(savedInstanceState);
    [javac]         ^
    [javac]   symbol:   variable super
    [javac]   location: class DefaultActivity
    [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:13: error: cannot find symbol
    [javac]         super.loadUrl("file:///android_asset/www/index.htm");
    [javac]         ^
    [javac] 5 errors
    [javac] 3 warnings
BUILD FAILED
D:\sdk\android-sdk\tools\ant\build.xml:716: The following error occurred while executing this line:
D:\sdk\android-sdk\tools\ant\build.xml:730: Compile failed; see the compiler error output for details.
Total time: 1 second
Build failed. Refer to the log above.
801
Adobe Employee ,
Oct 15, 2015 Oct 15, 2015
Hi Jsem,
Adobe Robohelp2015 release has come up with all new Mobile App SSL(single source layout). Mobile App SSL supports generation of iOS app along with Android. Please give it try and I am sure you will find this feature exciting. We have also published a blog to assist the user. Here is the link Create Mobile App using Adobe Robohelp 2015 « TechComm Central by Adobe
Mohd Sameer
Oct 16, 2015 Oct 16, 2015
yes .. but i was needed to build it offline without internet connection thanks  i have Rhl 2015 i will give try ..
The RoboHelp 2015 method is significantly easier than the methods for Rh10 and 11 but does require you to have an online connection.
If you email me direct I can send you some instructions for the earlier versions, just let me know which one you are using. However, I really would recommend the 2015 solution. You don't have to install any other apps.
@petergrainge
currently I'm using Robohelp 11 it would be nice to give us instruction of how to build it  ... i did put all needed paths i dont know what else should do .. i think from error log report compliant about needed class like apache.cordova..
Email as above. See the Contact page on my site.
RoboHelp Documentation
Download Adobe RoboHelp
