I have special problem with Adobe Presenter Video Express, when I want to use camera Logitech c920. (notebook Dell Vostro 3560, Windows 7- 64bit, 8 GB RAM, enough memory)
When I start the program and begin to create new project, I can see only black screen with error message "Your webcam is busy or it is not functioning. Try closing other applications that might be using the webcam and select it again". But when I press "record", program starts making video - and webcam works. My problem is that I can not use video effect to modify background - I can not see video/webcam preview with button "make my background awesome". When I switch to integrated webcam, It works without problems, including background-modifying function.
I closed every other program. I restarted notebook. I deleted and reinstalled drivers for camera. But it still does not work properly.
Any suggestions how to fix the problem?
Hi George,
In our tests we have seen that the Logitech C920, needs the latest Logitech driver and software to be installed for it to work properly. Please make sure you are picking the latest driver from the following link:
http://support.logitech.com/product/hd-pro-webcam-c920#download
If installing this driver doesn't fix this problem, then please try the following:
Hi George,
If the issue still isn't fixed, can we get on a Connect session to debug the problem? You can contact us at PVX-ProductionSupport@adobe.com with a suitable date and time, and we will resolve this through Connect. We are available Mon - Fri, 6:30 PM - 11:30 AM PST.
Thank you,
Renzil D'Souza (rdsouza@adobe.com)
Presenter Engineering Team
PS: As a temporary workaround, you can do the recording without changing the background, and then the change the background inside the editor using the 'Enhance Video' option.
It was my fault: I let windows reinstall drivers automatically ....Now I install drivers once again from suggested link manually and it works without problem.
Thanks for your quick and qualified response.
Have a nice day!
George
