Hello Tom,
We ran into the same problems when instantiating .net
objects with the Create Object calls. Our custom .net assembly goes
until TimeOut and then works from then on. The way we have gotten
around it is to create this object in the OnApplicationStart call
and then assign that object to an APPLICATION Scope variable. This
doesn't get rid of the problem, but it does make it invisible to
the user and allows us to only have to instantiate the object once.
Based on your post, you don't need advice on how to do this, but if
you do, don't hesitate to ask. I have also run across a LOT of .net
anomolies after installing hotfix 2 for CF8. They were so bad, we
gave up and went back to CF8 HotFix 1. Hopefully documentation for
the .net integration will become more extensive because right now
it is a LOT of trial and Error. We also had to develop a custom
conversion app to convert .net datatypes to coldfusion datatypes
because we are dealing with datatables of over 4000 rows and
ColdFusion would timeout (about 90 Seconds to convert). Using the
.net native calls [datatable.select()] and parsing the datatable
into a coldfusion query object dropped that down to about 9 or 10
seconds.
Don't know if this answered your questions, but at least it
lets you know there are other feeling the .net integration pain
with you. That being said, I LOVE all the new capabilities and
suspect the CF team will make it a lot better in the near future.
Bob
