Have an Imac with 10.5.8, what version of flash player can I get, and where can I download it from?...thank you.....Brian.
Hi brianc31061266,
Flash Player 10.3.183.90 is the last version supported on OS X 10.5.8. It's available at Archived Flash Player versions‌, however, it's very, very old and most likely will be blocked by most modern web browsers due to security vulnerabilities. Depending on your iMac's hardware you may be able to upgrade it to OS X 10.6 and be able to install the latest, most secure version (19.0.0.227). You can perform an internet search for 'upgrade OS X 10.5.8 to 10.6" and you'll get a bun
...Copy link to clipboard
Hi brianc31061266,
Flash Player 10.3.183.90 is the last version supported on OS X 10.5.8. It's available at Archived Flash Player versions‌, however, it's very, very old and most likely will be blocked by most modern web browsers due to security vulnerabilities. Depending on your iMac's hardware you may be able to upgrade it to OS X 10.6 and be able to install the latest, most secure version (19.0.0.227). You can perform an internet search for 'upgrade OS X 10.5.8 to 10.6" and you'll get a bunch of results, including requirements for upgrading 10.5.8 to 10.6.
Maria
