Is there anyone who has been able to get Presenter to work with SharePoint? I'd like to be able to share this work with my collegue but when we put the presentation on a shared drive the audio doesn't work.
Presenter has never played well with shared or external drives. Save the PPTX and folder with the presentation's name to your C drive to make any changes/edits and then you can move it back to Share point once you are done.
A better solution would be to package it using Presenter and un-package it locally. Then repackage it back to share point. This will ensure that all the appropriate files remain with the presentation.
Thank you Jorma@realeyes, I have no doubt this is a correct answer because this is what we're doing now. This is not however, what we want to do. because more than one person is working on this presentation at one time we need to be able to check out or in this presentation so that the changes are properly saved. Thanks again but still looking for a way to make these two play nicely togegther.
Best of luck. Try reaching out to Adobe here, Adobe Connect Help | Adobe Connect Support, and see if you get any other answer.
Thank you I will try that.
