I download the latest .MSI file to be install with SCCM. When the upgraded has been done the flash player stop working. I use the normal download from adobe and install it from the website and it worked correctly. I test using Facebook to look at some video and it work. Can you please verify or upgrade the MSI files on the Adobe Flash Player Distribution | Adobe
Regards
Hi martinl20025075,
The web version and the MSI versions are the same and both should work fine viewing the same content. To troubleshoot further, please provide the following information:
Thank you.
Maria
HI,
I use SCCM2012 r2 to deploy the MSI using a application deployment and using this command:
msiexec /i "install_flash_player_19_active_x.msi" /qn
My 2 machines I used to test before the deployment where using flash player 18 version 194
OS: wIndows pro 7 64 bit
Internet explorer 11.0.23
I uninstall the older version using this command:
msiexec /x {901E9B21-CDB1-4C4A-ABFC-61A554912BED} /qn
Like I said the application packages was deploy and flash was installed. But anything that use flash had a error that flash player not installed or must be updated.
If I use the website adobe.com and download and install Adobe flash player 19.0.0.226. All my flash application worked.
Then I uninstall flash player that was install using the web site and re-deploy it using SCCM2012. After that re-installation flash player 226 it worked correctly in internet explorer. I don't understand why it now worked on my machine.
I will try on 2 other machine using only the MSI and see what will happen.
