I used ADE 4.5 on Windows 10 for about a month then suddenly one morning, I was no longer able to execute ADE. I tried un-installing and re-installing 3 times. I get no error messages, just no response.
I'm having the same problem. I can get my books into ADE and then they just disappear.
Try this:
- Right Click on the Icon of Digital Editions.
- Choose start as Admin.
Thanks Nanaky but that didn't work either. The only difference was that when I ran as administrator, I got the message box, "Do you want to allow this app to make changes to your PC?" When I answered, "Yes", I got no response.
Try to install 3.0 Version an stand of 4.5: Adobe Digital Editions downloads
Thanks Nanaky. Getting closer but still have a little problem:
I installed ADE 3.0.1 as you suggested, and was able to download a book from my public library using Overdrive [I wasn't able to do this with ADE 4.5].
However, when I attempted to open the downloaded file in ADE, I got an error box, "Error: Check Activation".
What should I do?
Thanks Nanaky. Where do I find the name and location for the backup registry key that you mentioned in Step 7?
Name used this was get when save. The Place to save can used itself.
Thanks Nansky.
I'm sorry to be so dense but I didn't understand a word of your last post ("Name used this was get when save. The Place to save can used itself."). Could you dumb it down for me please?
I mean that can used the File Name which the system pretends.
The Place for the Save you choose yourself.
I am running windows 10 and was having similar problems and per Nanaky I closed ADE. Found the My Digital Editions folder in my documents and renamed it. I then open ADE and my books returned. They were filed in My Digital Editions. A couple of library books I had to re load but no biggie. Hope you are have luck.
not an answer but another question, sorry: ADE is weird on my new windows 10 machine, when it opens it flies off the monitor, i can find it on task view but can't use it otherwise what am i doing wrong?
