J'ai installé ADE 4 sur un second PC sous windows 7. Malgré le fait que l'autorisation de la machine montre bien mon ID Adobe je n'arrive pas à ouvrir mes livres. Quand j'essaie d'efffacer cette aurorisation adobe me signale "Impossible d'annuler l'autori
Feb 19, 2015 Feb 19, 2015
J'ai installé ADE 4 sur un second PC sous windows 7. Malgré le fait que l'autorisation de la machine montre bien mon ID Adobe je n'arrive pas à ouvrir mes livres. Quand j'essaie d'effacer cette autorisation adobe me signale "Impossible d'annuler l'autorisation. Veuillez réessayer ultérieurement". Ce que je fais depuis 3 jours sans résultat.
1.9K
Adobe Employee , Feb 19, 2015 Feb 19, 2015
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
ADE will be deauthorized now.
Now Authorize ADE again.
Adobe Employee ,
Windows:
Choose Start > Run.
OK, great : Thanks
Apr 16, 2015 Apr 16, 2015
Same problem but this doesn't work for me.
Even after deleting the Adept key my comptuter is still authorized and if I reopen the registry the key is right back where it was...
Please help. Thanks
Adobe Employee ,
ok, follow the below steps as listed.
1. Quit ADE.
2. Choose Start > Search for regedit
3. Right click on regedit, ans select "Run as admininstrator"
4.In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
5. Select Adept key, right click on it and select "Delete"
6. In the Confirm Key Delete dialog, click OK.
7. Close the Registry Editor.
8. Open Adobe Digital Editions and reauthorize.
Hope this works !!
Sep 30, 2015 Sep 30, 2015
Bonjour,
J'ai exactement le même problème sauf que je suis sur MAC. Mon ordinateur est marqué comme autorisé mais je n'arrive pas à ouvrir mes livres et un message d'erreur apparaît : Erreur lors de l'obtention de la licence. Problème de communication avec le serveur de licences :
E_ACT_NOT_READY
Si je fais la même procédure sur un autre support (Ipad), mon lien de téléchargement fonctionne.
J'avais autorisé mon ordinateur sur la version 3.0, et celle-ci ne me permet pas d'enlever l'autorisation
J'ai téléchargé la version 4.0, mais je reçois le même message d'erreur : "Impossible d'annuler l'autorisation. Veuillez réessayer ultérieurement"
Oct 27, 2015 Oct 27, 2015
J'aime même problème...
Oct 22, 2015 Oct 22, 2015
Tis
Thank you so much for giving me the right solution after 2 hours of search!
Great contribution for users
Nov 25, 2016 Nov 25, 2016
Hi Shreya,
Your tip has worked.
So long.
Laurent
