9 Replies Latest reply on Oct 23, 2015 6:02 AM by Obi-wan Kenobi
    Problem with text frame fitting when used on page number marker
    Angelica_Z Level 1
      Hello!
      I would like to use the text frame fitting on the page number marker on the master page in Indesign. The text frame should change by width when the page number increases. This doesn't work. What happens is that when the page number changes from one digit to two digits the numbers get pressed together (compressed on top of each other) and the text frame doesn't change size unless I drag it (which means I have to unlock it manually from the master page first).
      Am I doing something wrong, or is this a bug?
      Thank you!
