Some CC 2015 Applications Crash While Launching on Mac OSX
This article is reference to an issue wherein some CC 2015 applications crash when it is being launched or just after it is launched on Mac OSX. You might see the issue in the June 16th release of these applications.
Here are the solutions. Solution 1 should be able to fix the issue. In case it does not, please try solution 2 and 3.
Solution 1: Install Dreamweaver CC (2015)
Solution 2: Install Muse CC 2014.3.2
Solution 3: Install Acrobat Pro DC
Additional Information
Try turning off auto-hide menu bar in your system prefs -- that seems to be a trigger for crash on startup in El Capitan...
Solution 1 seems very curious: Why would InDesign CC 2015 crash on launch if Dreamweaver CC 2015 wasn't installed.
I typically install all the CC 2015 apps, but I can understand why many people would not. However, I don't quite understand how that would happen.
Dreamweaver isn't required, but installing Dreamweaver works around the problem by cleaning up some of the data files used by the installers.
OK, I guess that explains it. Not enough testing of the installers. There's no beta team for that except inside the Adobe firewall.
I've added this thread to my growing list of CC 2015 bugs.
Here is the KB article.
CC 2015 applications crash on launch | Mac OS
https://helpx.adobe.com/creative-cloud/kb/cc-2015-applications-crash-on-launch---mac-os.html
I've tried all of these suggestions (as well as a standard uninstall/reinstall of InDesign) and none of them work. Any more, please?
I'm getting Error 5.
Try asking on the Creative Cloud Download & Install forum:
None of these suggestions work. InDesign continues to crash immediately after startup. Extremely frustrating as I've missed a deadline and more deadlines are coming up.
I'm currently using:
iMac (Retina 5K, 27-inch, Late 2014)
OSX 10.11 (El Capitan)
4 GHz Intel Core i7
16 GB 1600 MHz DDR3
AMD Radeon R9 M295X 4096 MB
Oh my goodness! What a silly little thing that fixed everything! Thank you! That's all it was for me. That's so good, because I actually didn't really like when the menu bar would hide anyway.
Unchecking the 'automatically hide and show menu bar' in System Preferences > General fixed it for me too - after much head scratching, deleting of preferences, reinstalling CC interface and eventually having to run it through a new admin account. Thanks Peter!
OMG ... thank you! this worked ... been reinstalling apps, prefs, caches, fonts for the past 36hrs ... nothing worked ... would have never guessed this was the issue since AI and PS work fine in El Capitan
THANK YOU!!! Was going crazy trying to solve this problem!
Thank you so much. Installing Dreamweaver solved everything for some reason. No I just wish I could get the hour of my life back I just spent trying to figure out why Indesign CC 2015 wasn't opening.
it work!!!!! so simple! instanly! Best answer ever... how you came up with it!?
Deleting the preferences by holding shift+control+option+command right after you click the indesign icon to open the program also works.
This is what worked for me: thanks!
Deleting the preferences by holding shift+control+option+command right after you click the indesign icon to open the program is what worked for me. InDesign was opening fine until I forced quit it on a huge file (700+ pages with 12 thumbnails on each page) Since then it didn't want to restart at all. Solved now!
Thank you for this.
ooohhh thank you!!!!!!
Premiere Pro CC 2015 just starting stalling at launch with a spinning beach ball. This happened on two machines (linked only by Raid) at the same time in our studio. We are on Yosemite so the option stated above in System Preferences doesn't exist in Yosemite General System Prefs. I guess it's new in El Capitan. Any solutions for Yosemite?
You should probably ask about this over in the Premier Pro forum...
Updated my inDesign CC program today (2015 version). Program crashes during opening at "calling late initializers." I have tried all of the above, Solutions 1, 2 & 3 and thrown out preferences as per instructions above. Using Mac Mini (late 2014), Yosemite 10.10.5. Is the only solution to go back to the previous version of inDesign? Thanks!
It's worth a try at uninstalling and reinstalling InDesign CC 2015.3.
Here are instructions for doing that:
Thank you, that did the trick! And the article with additional tips is very helpful as well.
