Conditional Build based on client name - RH 10
Oct 26, 2015 Oct 26, 2015
Hi there,
I use Robohelp 10, and create a webhelp for our software product. All our clients are from the same domain. We now have increasingly started to encounter a situation where Client A uses different field names, sees a different set of fields or even uses a different version of our product than Client B. The webhelp is deployed as per the version of the software a client uses.
Is there a way I could use the conditional build tag to create a webhelp output that picks topics based on client names. (This might not be ideal as there might not be space on the server to host many versions of the webhelp!)
Or even if a topic is included in the webhelp, is there a way that it gets displayed only if the code indicates it is client A or B?
I would really appreciate any suggestions on the best strategy to be adopted here.
Thank you,
S Augustine
248
Oct 27, 2015 Oct 27, 2015
Variables would enable you to create different outputs for different clients but each would need to access a different output. I think the first thing is to ascertain the number of outputs you can host. If insufficient some other solution has to be found, such as locally installed help for each client. That could be client machine based or on their intranet.
@petergrainge
Oct 28, 2015 Oct 28, 2015
Thanks Perter. Server space is a definite concern and hence having different copies of the webhelp does not look like a solution. Also, access to client intranet would not work for most due to the nature of the domain.
I might have to stick with standard field names in the webhelp, and put in notes about variations.
S Augustine
Sorry Peter, not Perter.
RoboHelp Documentation
Download Adobe RoboHelp
