I can't erase the authorization for Adobe Digital Editions. I get the same message over and over again. Unable to erase Authorization. Please try after some time. Need help.
Which operating system do you used?
Windows 10. I ended up installing an earlier version (3.0.1) which enabled me to erase the authorization. I re-installed the latest version and corrected the e-mail address associated with the account. I had set it up with the wrong e-mail account when I re-installed it to a new hard drive.
Thank you for the follow-up
Chris
I have the same issue with Digital Editions 4.5 on Win10. Did you ever get a fix for this issue? I have tried uninstalling and reinstalling, but somehow it retains my adobe ID so I can't even get around it that way.
Closed Digital Edition. Remove the authorize over Help Authorize remove and then authorize again.
That doesn't work. All I get is the error message indicated in the original post.
I worked for me. Try this
1. Close all applications.
2. Choose Start > Run.
3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
5. Select the Adept key.
6. Choose File > Export.
7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
8. Right-click the Adept key and choose Delete.
9. In the Confirm Key Delete dialog, click OK.
10. Close the Registry Editor.
11. Open Adobe Digital Editions and reauthorize.
I installed the earlier version 3.0, erased it’s auth and then installed 4.5.
