unleashed wrote:
> I have an XML document that I'm trying to turn into a
query, but I'm getting an
> error: "Element P is undefined in MYDOC." I have an
element called "P-Info"
> and I think that the code doesn't like the dash.
> I am trying to extract the TS, Latitude, Longitude and
Own values out of the
> XML document.
> CFML Document:
> <cffile action="read" variable="xml"
file="#ExpandPath('.')#\sample.xml">
> <CFSet mydoc = XMLParse(xml)>
> <cfset pb = mydoc.META.P-Info.xmlChildren>
> <cfdump var="#pb#">
Yes, when you use dot notation every element must be a valid
ColdFusion
variable name which means no spaces, dashes, ect.
If you have elements like this you must use array notation.
I.E. <cfset pb =
mydoc["meta"]["p-info"]["xmlChildren"]>
OR if you don't mind mixing dot and array notation.
<cfset pb= myDoc.meta["p-info"].xmlChildren>
