Okay, the other day I installed Photoshop, Adobe Flash Player and Adobe Premiere and then I decided to install Dreamweaver and that's when things went pear shaped. No matter what I have tried (reading through the forums) I cannot get it to install. Here are the errors I am getting:
Installer has detected that a machine restart may be pending. It is recommended that you quit the installer, restart and try again.
or if I decide to not quit the installer I get an Exit Code: 7 message:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 3 error(s), 6 warning(s)
WARNING: OS requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
WARNING: OS requirements not met for {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
WARNING: OS requirements not met for {C79312BD-3E76-4474-A10C-1435D1856A4B}
WARNING: Display requirements not met for {FBB02B04-C034-4382-A3F6-57416E2752C4}
WARNING: OS requirements not met for {FBB02B04-C034-4382-A3F6-57416E2752C4}
ERROR: Found payload conflicts and errors:
ERROR: - Adobe Flash CS5 depends on Adobe Flash Player 10 ActiveX to be installed.
ERROR: - Adobe Flash CS5 depends on Adobe Flash Player 10 Plugin to be installed.
FATAL ERROR: Conflicts were found in the selected payloads. Halting installation.
I have tried all of the suggestions here:
Errors "Exit Code: 6," "Exit Code: 7" | CC, CS6, CS5.5
Such as
Exit Code: 6, Exit Code: 7 Installation Errors - http://helpx.adobe.com/creative-suite/kb/errors-exit-code-6-exit.html
Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html for information on how to review your installation logs
Thanks Sheena, this did not work either, however I have found the solution.
If you had read my post properly you would have seen that I have already tried your suggestions
Thanks to 7Guru7's response found here: can't install Adobe CS6: machine restart may be pending I used the solution they found here: The VaderVideo Blog Frames | Camera Imagery and Imagination Explained in Words: Adobe Creative Cloud...
This is the solution here, which is part of a conversation they had with Adobe Tech Support:
Vijendra: May I know if you are logged in as Administrator to the computer?
Andreas: I am
Vijendra: May I know if you have a 32 bit or 64-bit operating system?
Andreas: 64 bit, win 7
Vijendra: Please navigate to C:\Program Files (x86)\Common Files\Adobe
Andreas: am there now
Vijendra: Inside Adobe folder do you have a folder called OOBE?
Andreas: yes
Vijendra: Please rename that folder to OOBEold.
I restarted the computer before trying to reinstall CS5 Master Suite and this time it installed without a glitch.
