I need help with setting association with Adobe Digital Editions. It keeps trying to open as Adobe Reader DC and when I go to set associations wants me to open a specific folder inside Digital Editions.
I had uninstalled and reinstalled due to a separate error. I tried uninstalling and reinstalling again to no avail.
Set is in your system as standardprogram for epubs files.
I don't understand how to change it. Which folder inside Digital Editions to change it to.
Not in the folder. In the Setting of his operating system. Which operating system do you used?
Windows 7 Professional
Right Click on a ePub file.
Choose Setting.
In this windows see the Program which ad to open the file.
Click on the Butten and chance digital edition in C:\Program(x86)\Adobe\Digital Edition
When I go to open an epub file and try to choose I have to hit browse and then when I pick Adobe Digital Edition folder it then opens with more folders to pick from and I'm not sure which one is correct. Each folder opens more folders. If I know the specific folder inside Adobe Digital Editions I can then select it.
You must choose the application File for Digital Edition. You can also try this way, when you not found the right File. Change which programs Windows uses by default - Windows Help
Ok that worked and now it's back to the original error I had before I deleted and reinstalled which is:
error getting license license server communication problem E-AUTH-BAD-DEVICE-KEY-OR-PKCS12
Start Digital Edition.
Go to help > Remove authorize.
Accept this.
Then authorize again and check download again.
Thank you for your help. WHen I go to sign in after erase authorization it says:
It's saying unable to erase authorization. Please try after some time.
Do you used Windows or Macintosh?
