I've upgraded to ADE version 4.5. Since then
I have not been able to open newly downloaded books from my library or transfer to my Kobo ereader with this version.
Could you please provide more information like platform you're using (Windows, Mac) and the error message you're getting.
Thanks.
Mehvkhan;
I’m using Windows 8.1. Error message is “ADE 4.5 has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.” It’s notable that I can open books which were entered into my library with the previous ADE version. However the two books I loaded into the library cause the error message identified when I try to open them.
Mark
Can you open Digital Edition directly?
I only have opened ADE through Windows. I’m not aware of your any alternative or “directly”.
Mark
Go to C:\Programme(x86)\Adobe\Digital Edition Version and try start in this the digital edition.
I tried via the C drive. Same result.
FYI; I did uninstall and re-installed ADE 4.5.
Mark
Is it possible to go back to an earlier version of ADE?
You can try it with 3.0: http://www.adobe.com/support/digitaleditions/downloads.html
I installed the 3.0 version. When I attempt to open a book in my library I’m getting an error message “Activation Sever Error. Code E_ADEPT_INTERNAL” Digital Editions encountered an error on the activation server.
Help!
To solved the error used Error "E_ADEPT_INTERNAL" | Download protected e-book | Digital Editions
But can not found a download for 4.0
Is 4.0 available to download?
