1
how to change language in Acrobat pro DC
Nov 05, 2015 Nov 05, 2015
Install update and subscribe to Acrobat
58.6K
Adobe Employee , Nov 05, 2015 Nov 05, 2015
Hi Erik,
Open Acrobat
Go to Edit > Preferences > Language
Under Language pane
Click on the drop down for Application Language and select the option Choose at Application Startup
Click Ok and Close the application
Launch Acrobat again, it will give you a drop down to select the language
If in case, you do not see the language which you want and is available with Acrobat
Then go to Control Panel
Add or Remove Programs
Select Acrobat Pro from the list and click on Change
From Acrobat dialog box, you will get
Adobe Employee ,
Hi Erik,
Open Acrobat
Under Language pane
From Acrobat dialog box, you will get 3 option Modify, Repair or Remove
Select Modify and next
Then on the next window
Click on the + sign before Languages
Click on the down arrow for the language you would like to install and select the 2nd option and Install
Let me know if this helps.
Abhishek
Nov 07, 2015 Nov 07, 2015
Thank you exactly what I was looking for. It is obviously not in Creative Cloud to change it ... Although Adobe writing such .
Hilsen Anders
Mar 24, 2017 Mar 24, 2017
Dear Abhishek,
Thanks for the information but no offense.. my problem didn't solve! i follow everything but when it comes to modifying the languages there's no choices for any languages that i needed to install.. do you have any ideas you want to share??
Thanks..
Contributor ,
Jun 25, 2019 Jun 25, 2019
Die Frage wurde nicht beantwortet. There is no, or not anymore, a possiblitye to select a plus sign for any langauge during the modify installation.
Could someone moderate this false information?
What language version of Adobe Acrobat does you have?
Contributor ,
Jun 27, 2019 Jun 27, 2019
English
Is the language of the UI in english or not?
Mar 24, 2023 Mar 24, 2023
Thank you!!
Apr 05, 2023 Apr 05, 2023
I can't follow the instructions to change from Russian since I can't read Russian
Jul 04, 2016 Jul 04, 2016
For me it doesn't work.... the windows don't show what is described in the solution.
The language won't change!
Contributor ,
Unfortunately selecting modify during installation does not allow the user to select other languages.
How do we Install additional spell check langauges in Adobe Acrobat DC?
Dec 24, 2019 Dec 24, 2019
Hi! It didn't work. I tried to add language Bangla. But there is no option of Bangla. In fact, there are few languages which can be added. Any idea how to add any language?
Feb 29, 2020 Feb 29, 2020
It helps, thank you very much!
And it allows to use both languages: Russian, or English, whatever I need!
Galina
