I cannot get Digital Editions to authorize my computer. It returns an error message "Digital Editions could not connect to the activation server. Please make sure you are connected to the Internet." My internet connection is fine. Any suggestions?
Guest
May 05, 2015 May 05, 2015
I
1.2K
Adobe Employee ,
Hello,
Quickly you can do a check.
Open your browser
Type URL: https://adeactivate.adobe.com/adept/Status
Press enter
You should see something like:
If it says "UP", this indicates ADE will be able to contact activation server.
If not, then, maybe firewall is causing you this issue.
May 06, 2015 May 06, 2015
I am having the same exact problem! I did what Shreya said, and it still did not work. Any suggestion?
Guest
No solution yet to the problem.  I tried what Shreya suggested but the authorization still wont go through.
Thanks .
May 07, 2015 May 07, 2015
I'm having the SAME problem.  I can log in to Adobe with my ID & password, yet I cannot open my NCLEX-RN Review eBook.  I have a 4 day seminar coming up that requires 100 hours of prep time.  I *need* that book!!!  I ran the link posted above and it displayed "UP".  Still can't open the file.
Adobe Employee ,
ok, try restarting your machine.
you are facing this problem on Windows or Mac ?
Rebooted several times. That's not helpful
Adobe Employee ,
Windows or Mac??
Windows 7
I've Uninstalled/Reinstalled twice. I've deleted temp files. My Internet
connection is fine. No issues accessing anything. I've changed firewall
settings.
Nothing is allowing me to open the eBooks
Guest
May 11, 2015 May 11, 2015
My machine runs Windows.
Guest
Restarting does not help at all.  Nothing changed.
Adobe Employee ,
May 12, 2015 May 12, 2015
Would you be able to try the below on your Windows machine and then test if this resolves the issue.
1. Click Start > Control Panel > Windows Firewall
2. On the left column, please click "Turn Windows Firewall on or off".
3. Now select "Turn off Windows Firewall" option under each of the heading for "Domain network location settings", "Home or work network location settings" and then also under "Public network location settings".
4. After selecting this for each of the 3 settings, then click OK.
5. Now close all Windows and then launch Adobe Digital Editions and test if you are able to authorize.
In case this works, then please let me know and I will share the settings that would allow you to use Adobe Digital Edition with Windows Firewall Enabled.
Sharad
May 13, 2015 May 13, 2015
sharad tried everything mentioned in the post
but nothing is helping out
might be there is some bug in this version. it just dont go past authorizing for hours.
That did not work
Guest
May 19, 2015 May 19, 2015
Hey Guys!
Problem resolved!  What I did was 1.  Dumped ADE version 4.0 2.   Installed ADE 3.0 3.  Re-downloaded the ebook
It worked like a charm!
I ended up downloading Kindle on my laptop and getting the eBooks through
Amazon since I had to have these books for a class and could no longer wait
for someone to figure out how to fix it.
I'll have to see if using the old version of Adobe Digital Edition will fix
my issue. Thanks for sharing this.
On May 19, 2015 10:25 PM, "robertw65423669" <forums_noreply@adobe.com>
Nov 05, 2015 Nov 05, 2015
Thank you!  I was having the same issues, and your solution worked for me, as well.
Aug 04, 2015 Aug 04, 2015
I still get this internet connection error even when I turn off the firewall. I tried adobe 3.0 and 4.0.3. Any other suggestions?
Adobe Employee ,
May 10, 2015 May 10, 2015
In case you have checked that internet is working fine on the machine, then I would suggest you to try the below and check if this fixes the issue.
On Windows machine,
  1. Choose Start > Run,
  2. Type  %systemroot%\system32\drivers\etc
  3. Then press Enter.
  4. Now look for file named as "hosts" and rename this file to "hosts_OLD"
  5. Now launch Adobe Digital Editions and try authorizing.
  6. Once it works, navigate back to the above "hosts_OLD" file and rename it back to "hosts".
Please try this and let me know in case this helps in resolving this issue.
Some context about this file:- Operating system hosts files map host names to IP addresses. An incorrectly configured hosts file can affect your computer's ability to connect to Adobe's activation servers and may cause some unexpected errors.
Sharad
That did not work. I still get the same error message.
On Sun, May 10, 2015 at 4:41 PM, Sharad Vatsa <forums_noreply@adobe.com>
Guest
Thanks Sharad but the problem remains.  There is still no authorization possible.
Aug 05, 2015 Aug 05, 2015
The solution of robertw65423669 works for me. I deinstalled version 4.0.3 and Installed version 3.0. I'm using Windows 7 Ultimate and ESET Nod 32 Antivitus and Firewall.
After validating the ID I got the following error: Error obtaining the license:  E_ADEPT_REQUEST_EXPIRED.
After restarting Digital Editions it works. I think that version 4.0.3 have many issues.
Thank you.
