Cannot Access CF11 Developer except from the CF Server
Nov 05, 2015 Nov 05, 2015
I just installed ColdFusion 11 Developer on a Windows 7 system.  I am using the internal web server.  I can access CF apps from the server using http://127.0.0.1:8500/CFIDE/passme/hello.cfm, but when I attempt to access CF from my laptop, I get "Cannot locate internet server.  I have attempted to access the server using its real IP but also fail.
462
Explorer , Nov 07, 2015 Nov 07, 2015
It turned out to be a firewall issue. CF support assisted me yesterday and I’m up.
Thanks for the help.
CFIDE is a system directory. You shouldn't develop custom code withn it.
Place your custom code in the root directory, C:\ColdFusion11\cfusion\wwwroot. For example, create the directory C:\ColdFusion11\cfusion\wwwroot\passme\ and copy your hello.cfm file into it. Then open this in a browser
http://127.0.0.1:8500/passme/hello.cfm
This works on the server, but not from my laptop. Since I'm getting a generic error and not a CF error, it appears that the laptop is not  to be finding ColdFusion at all
Guide ,
Hello,
What URL are you using on your laptop?
Regards, Carl.
Nov 06, 2015 Nov 06, 2015
I have tried:
127.0.0.1/cfide/passme/hello.cfm
127.0.0.1:8500/cfide/passme/hello.cfm
Guide ,
Suggest from your desktop try the servers tcp address EG:
http://10.0.0.1:8500/CFIDE/passme/hello.cfm
or
http://10.0.0.1/CFIDE/passme/hello.cfm
HTH, Carl.
Hang on. Have you installed ColdFusion on your laptop? I am assuming you have.
If you haven't, then your laptop will have to be able to reach the server. Get the IP of the server in the network, say, x.x.x.x, then use http://x.x.x.x:8500
If you paid for that support, I hope for your sake that you may have called before I offered the same suggestion here yesterday: “you will likely need to open that port in your firewall to be accessible off the server.” ;-}
/charlie
/Charlie (troubleshooter, carehart.org)
I emailed Adobe prior to seeing your post. Their support was at no charge.
Thanks for your concern.
Regards John
John, besides what the others have said, if you WILL be leaving your code in the CF wwwroot, and WILL be trying to access it from off the server using that port, then you will likely need to open that port in your firewall to be accessible off the server. I suspect THAT is why it's not working for now. Ports other than 80 are typically blocked by default for remote access on all machines.
But as BKBK said, you don't really want to put your code in the CF wwwroot anyway, typically (which requires you to use that built-in web server port). And there are still other security reasons it's best not to open that built-in web server port anyway.
So really, you'd typically use some other web server on the serve (IIS, Apache, nginx), and define a web site there pointing to the code, and then configure that site to pass requests to CF. (That may have been done initially in the installer, but since you show using the built-in web server, I suspect you did not choose that option.) After installation, you can connect a site in an external web server to CF using the CF web server configuration tool.
Let us know if this helps.
Documentation
