Hi, I have downloaded purchased material on Adobe 3, however I cannot print. I purchased it with a licence to print for 1 yr. The support from the seller has not been helpful. Any ideas?
Which error message you get?
No error message, just when I press file at top left the word 'print is not in bold so doesn't work
Sent from my iPhone
The function for print is gray out? It works with Ctrl + P or CMD + P?
Hi Nanaky, that doesn't work either. I have a Pavillion hp. Any other suggestions, gratefully excepted?
Should work fine. Try if works with this file: http://contentserver.adobe.com/fulfillment/URLLink.acsm?action=free&ordersource=operator&r esid=urn%...?
yes, it does, the print comes up fine when I press file!
Then the other file no permissions to print. When you buy the eBook with this option should contact the Creater of the File that a error in the file.
Thanks, I will contact them again with this info, hopefully I can get it rectified!
Good Luck.
Yes so it looks like I can print the Sherlock holmes file you sent but not the schema E-book I purchased that is suppose to allow me to print for 1 yr. They are actually questionnaires to use with clients, any other tips?
