Debug on device was working fine, then suddenly stopped a couple of weeks ago.
I think this coincided with an iTunes update but can't be sure cos I've spent a few days since. reloading many versions of Air compilers, iTunes, and trawling through dozens of related posts for same problem with older Air/iTunes combos and forgot how it all started!
Current error on debug compile of Mobile ActionScript project to iPad Air2 Device creates the ipa file then fails on install to device with error "Unable to enumerate devices".
"idb.exe -devices" from Air 19.0 compiler does detect attached devices correctly.
I have tried :
- uninstalling all Apple programs( iTunes, MobileDevice Support, Bonjour, Apple Software Update, Application Support(32&64bit)) and Java and Adobe FlashBuilder then re-installing after a reboot.
- Creating a new Flash Builder Project
- installing Air 3.4, 18.0, 19.0
- installing iTunes 12.0.1, 12.1.3(for old video cards), 12.2.2(for old video cards), 12.1.2, 12.2.2, 12.2.25
- ios 8 and 9.0 on the ipad
Different combos give different errors, but none working.
I can load ipa to device using iTunes but debug compile won't connect to debugger on usb.
Will also load to simulator but as app is for Retina display I can't see whole app on screen (but that's another problem -_- )
This problem seems to have been around for a few years with each new Air/iTunes combo.
Does anyone have a current solution?
Issue resolved with Air 20.0 beta.
Solution to this problem posted by Adobe Air team here:
post no. 39
This happened with AIR 17, and they fixed it. Looks like it's happened again and Adobe's admitted it and needs to fix it again, see "piyushb89979246"'s recent post (9/20/2015) on this thread:
AIR 17 iOS - Unable to enumerate devices.
I wish I had never updated iTunes -- totally derailed my development process not being able to do a proper debug.
it tells "CFNetwork module LOADED" after using the mini patch ...
What 'mini patch' are you referring to Jared?
post no. 39
