You say: "My sys admin controls the path for My Documents and
that is networked to a VERY slow drive." Yikes!
"My Documents...networked" (and yes, JohnInCO, mapped drives
are networked) cannot work with RH, period (even fast drives don't
help). RH must be installed on your local machine, under your login
with administrator privilege, and you must then work with your
projects on that local machine. Then, you
generate to your local machine and
publish to any network you want.
If your sys admin refuses to recognize these restraints,
first collect the 7th blue bar and the 10th blue bar, and then go
to your sys admin's cube and WHACK HIM OVER THE HEAD WITH THEM!
Good luck,
Leon
