Hello ,
If I want to Find & Replace, how can I ask Find & Replace to search for something with a non-breaking space?
For example, 250_kg (_ being the non-breaking space) that needs to be replaced by 400 lb.
Use the dialogue box code for the non-breaking space, e.g. \<space>.
For more details on these codes, see: http://help.adobe.com/en_US/framemaker/using/WSd817046a44e105e21e63e3d11ab7f7862b-7fd5.html
Hello.
I have similar problem. I have text where non breaking space is present and some where not.
So now I want to search for both of them.
Let's say I have text "L_2" and "L 2", where _ is non breaking space and the other one is normal space.
How I can search for both occurrences. I tried it in FrameMaker12 with regular expression, but then the "\ " is not working.
re: Let's say I have text "L_2" and "L 2", where _ is non breaking space and the other one is normal space. How I can search for both occurrences.
Search for L[ \ ]2
with Use Wildcards enabled.
Searching on L*2 or L?2 with Wildcards should also work, but doesn't, at least on FM7.
Thanks a lot. This works !!!
Are there any other options for em-space and other spaces? Or this will work for all spaces?
re: Are there any other options for em-space and other spaces? Or this will work for all spaces?
Searching for [\x10|\x11|\x12|\x13|\x14|\x20]
with Wildcards enabled
finds all the spaces supported by FM7.
\x20 is hex notation for the normal space.
Not having FM8 or later, I can't tell you if the search dialog also supports \u1234 Unicode notation.
I think we're in luck here … one quick test has FM12 finding a character via Unicode.
