Hi everyone!!
While browsing & uploading images from local drive I need to save the uploaded image in a folder at server (PHP)
It has to be done automatically once the uploading is finished.
Here is the code:
import flash.events.MouseEvent;
import flash.net.FileReference;
import flash.net.FileFilter;
import flash.utils.ByteArray;
import flash.events.Event;
import flash.events.IOErrorEvent;
import flash.display.MovieClip;
import fl.controls.ProgressBarMode;
var mFileReference:FileReference;
// Setup button to handle browsing
browseButton.buttonMode=true;
browseButton.mouseChildren=false;
browseButton.addEventListener(MouseEvent.CLICK, onBrowseButtonClicked);
// Hide progress bar
progressBar.visible=false;
// This function is called when the BROWSE button is clicked.
function onBrowseButtonClicked(event:MouseEvent):void
trace("onBrowse");
mFileReference=new FileReference();
mFileReference.addEventListener(Event.SELECT, onFileSelected);
var swfTypeFilter:FileFilter = new FileFilter("SWF/JPG/PNG Files","*.jpeg; *.jpg;*.gif;*.png");
var allTypeFilter:FileFilter = new FileFilter("All Files (*.*)","*.*");
mFileReference.browse([swfTypeFilter, allTypeFilter]);
// This function is called after user selected a file in the file browser dialog.
function onFileSelected(event:Event):void
trace("onFileSelected");
// This callback will be called when the file is uploaded and ready to use
mFileReference.addEventListener(Event.COMPLETE, onFileLoaded);
// This callback will be called if there's error during uploading
mFileReference.addEventListener(IOErrorEvent.IO_ERROR, onFileLoadError);
// Optional callback to track progress of uploading
mFileReference.addEventListener(ProgressEvent.PROGRESS, onProgress);
// Tells the FileReference to load the file
mFileReference.load();
// Show progress bar
progressBar.visible=true;
progressBar.mode=ProgressBarMode.MANUAL;
progressBar.minimum=0;
progressBar.maximum=100;
browseButton.visible=false;
// This function is called to notify us of the uploading progress
function onProgress(event:ProgressEvent):void
var percentLoaded:Number=event.bytesLoaded/event.bytesTotal*100;
trace("loaded: "+percentLoaded+"%");
progressBar.setProgress(percentLoaded, 100);
// This function is called after the file has been uploaded.
function onFileLoaded(event:Event):void
var fileReference:FileReference=event.target as FileReference;
// These steps below are to pass the data as DisplayObject
// These steps below are specific to this example.
var data:ByteArray=fileReference["data"];
trace("File loaded");
mFileReference.removeEventListener(Event.COMPLETE, onFileLoaded);
mFileReference.removeEventListener(IOErrorEvent.IO_ERROR, onFileLoadError);
mFileReference.removeEventListener(ProgressEvent.PROGRESS, onProgress);
browseButton.visible=true;
var movieClipLoader:Loader=new Loader();
movieClipLoader.loadBytes(data);
movieClipLoader.contentLoaderInfo.addEventListener(Event.COMPLETE, onMovieClipLoaderComplete);
function onFileLoadError(event:Event):void
trace("File load error");
// This function below is specific to this example.
// It does the processing required to display the swf/png/jpeg file that we have just loaded.
function onMovieClipLoaderComplete(event:Event):void
var loadedContent:DisplayObject=event.target.content;
var loader:Loader=event.target.loader as Loader;
// Fit to stage
trace("loadedContent.width="+loadedContent.width);
loadedContent.scaleX=container.width/loadedContent.width;
loadedContent.scaleY=container.height/loadedContent.height;
trace("loadedContent.scaleX="+loadedContent.scaleX);
trace("this.stage.width="+this.stage.width);
container.addChild(loader);
