Create Soap webservice
Guest
Mar 14, 2008 Mar 14, 2008
Is there any example available for soap in coldfusion? So i can invoke soap to cfc webservice.
Advanced techniques
2.0K
Other then creating a CFC method with an 'access="remote"' parameter as
described in the documentation available on the internet and elsewhere?
http://livedocs.adobe.com/coldfusion/8/htmldocs/webservices_17.html
Guest
Then what is soap.. Is it possible to access this test.cfc?wsdl in php or java. Can I call that. What is useful for soap. why people using soap
Nick201 wrote:
> Then what is soap..
"Simple Object Access Protocol" originally, but now just "SOAP"
http://en.wikipedia.org/wiki/SOAP
Yes. The nice thing about ColdFusion is by simply adding
"access='remote' to a CFC function (aka method) ColdFusion
auto-magically builds the required SOAP WSDL interface. Just point
anybody who wants to consume your web service to uri (i.e.
'test.cfc?wsdl' and they should be off and running.
To exchange data across this new fangled thing called the 'internets'.
Guest
SO I someone request a DATA using my WSDL query then will get result set back right
That's the idea, sort of, more or less.
They request data using the 'web service' you build. Which ColdFusion
make rather painless --- usually. But when it is not painless it can be
quite frustrating.
The WSDL "Web Service Definition Language" is what tells anybody trying
to use your web service what is its API. I.E. What are the methods,
what arguments do these methods need and what do they return.
ColdFusion generates this file automatically when you designate at least
one method in a CFC as "access='remote'" and thus a web service.
So "WSDL query" is not a phrase that makes much sense.
Guest
Is there any example of query invoke webservice. Thanks
I'm not sure what type of an example you want. English seems to be a
bit of a barrier here.
But a simple method that returns a query.
<cfcomponent>
<cffunction name="aMethod" returnType="query" access="remote"
output="false">
<cfset var returnQry = "">
<cfquery name="returnQry" dataSource="aDSN">
SELECT aField
FROM aTable
</cfquery>
<cfreturn returnqry>
</cffunction>
</cfcomponent>
Guest
Mar 17, 2008 Mar 17, 2008
I am running this issue here. I am getting this error message when I passed argument.
Web service operation "aMethod" with parameters {first_name={John}} could not be found.
Any idea thanks.
<cfcomponent>
<cffunction name="aMethod" returnType="query" access="remote" output="false">
<cfargument name="first_name" type="string" required="yes">
<cfquery name="returnQry" dataSource="abc">
SELECT first_name
FROM empwhere first_name='#ARGUMENTS.first_name#'
</cfquery>
</cffunction>
</cfcomponent>
<cfinvoke webservice=" http://catburg/test.cfc?wsdl" method="aMethod"
returnvariable="detailinfo">
<cfinvokeargument name="first_name" value="John">
</cfinvoke>
<cfdump var="#detailinfo#">
> argument.
> be found.
> Any idea thanks.
You may need to 'refresh' the web service in the ColdFusion
Administrator. ColdFusion caches the signature of a web service and it
must be refreshed if the signature changes.
A signature of a web service is it's URI, the names and return types of
the remote methods as well as the names and types of any arguments
passed to these methods.
If you created the method without the argument, for example; tested the
code; then added the argument - you would need to refresh the web
service in the Administrator.
Guest
Thanks. It works internally ok. But if i am calling from other server I am getting this error message. Any idea
AXIS error
Sorry, something seems to have gone wrong... here are the details:
Fault - Error attempting to create Java skeleton for CFC web service; nested exception is:
coldfusion.xml.rpc.CFCInvocationException: [coldfusion.xml.rpc.SkeletonClassLoader$UnresolvedCFCDataTypeException : Could not resolve CFC datatype:
AxisFault
faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.generalException
faultSubcode:
faultString: Error attempting to create Java skeleton for CFC web service; nested exception is:
faultActor:
faultNode:
What is the other server running?
If it is not ColdFusion, you may have trouble with a query return type.
Unfortunately a record set is not a universally implemented from
language to language. You may have to transfer a more basic complex
type such a structure or array.
Guest
I have created cfc in my test server and I am calling cfc from my local machine (coldfusion server)
Also Do you have any example of basic complex type such a structure or array.
What do you get if you put the URI " http://catburg/test.cfc?wsdl" into
browser? Do you get the WSDL file? Or perhaps some connection error?
There maybe permissions problems and this should show it up.
<cfset basicAry = arrayNew(1)>
<cfset basicAry[1] = "something">
<cfset basicStruct = structNew()>
<cfset basicStruct["aKey"] = "something else">
Guest
You mean function return type query will cause problem. If I call this WSDL in .NET.
Coluld you please give me example of basic complex type such a structure or array in webservice.
Nick201 wrote:
> Thanks,
It might. I do not know for sure from personal experience. But I
understand that 'query' means somewhat different things to different
languages.
<cffunction name="anArray" returnType="array" access="remote"
output="false">
<cfset var returnVal = arrayNew(1)>
<cfset returnVal[1] = "something">
<cfreturn returnVal>
</cffuntion>
<cffunction name="aStruct" returnType="struct" access="remote"
output="false">
<cfset var returnVal = structNew()>
<cfset returnVal["aKey"] = "something">
</cffuntion>
If this is required, it is fairly easy to loop over a query and rebuild
it as either a set of nested arrays and|or structures.
Guest
could you please give me one working example of array or struc with query. I also would like to know how to output.
here is my code.
Since this function declare as array so this cfc should work with other programs. such as Java, . Net etc right?
<cfcomponent>
<cffunction name="aMethod" returntype="array" access="remote" output="false">
<cfquery name="returnQry" dataSource="test">
SELECT top 10 first_name,last_name
FROM emp where first_name='#ARGUMENTS.first_name#'
</cfquery>
<cfset myarray=arraynew(2)>
<!--- Populate the array row by row --->
<cfloop query="returnQry">
<cfset myarray[CurrentRow][1]=first_name>
<cfset myarray[CurrentRow][2]=last_name>
</cfloop>
<cfreturn myarray>
</cffunction>
</cfcomponent>
<cfinvoke webservice=" http://catburg/array.cfc?wsdl" method="aMethod"
<cfinvokeargument name="first_name" value="viki"/>
</cfinvoke>
> here is my code.
That's the idea. An array is a more universally implemented variable
type, thus it is supposedly more portable across disparate environments.
You have the right idea on how to loop over a query and create it as a
two-dimension array. To output you just have to go old school and write
your own iteration loops to handle it. Something along these lines:
<cfoutput>
<cfloop from="1" to="#arrayLen(detailInfo)#" index="foo">
<cfloop from="1" to="#arrayLen(detailInfo[foo])#" index="bar">
#detailInfo[foo][bar]#<br/>
</cfloop>
<hr/>
</cfloop>
Guest
I am getting this error with webservice.. If i used componets i am not seeing any problems. Any idea thanks.
Could not perform web service invocation "aMethod".
Here is the fault returned when invoking the web service operation:
java.lang.NullPointerException
The error occurred in /var/www/html/tarang/qarray1.cfm: line 3
1 :
2 : <cfinvoke webservice=" http://catburg/qqarray.cfc?wsdl" method="aMethod"
3 : returnvariable="detailInfo">
4 : </cfinvoke>
5 :
<cfcomponent>
SELECT first_name,last_name
FROM emp where first_name='Danny'
</cfquery>
</cfloop>
<cfreturn myarray>
</cffunction>
</cfcomponent>
Call webservice
</cfinvoke>
<cfoutput>
</cfloop>
<hr/>
</cfloop>
</cfoutput>
Sorry, I don't see any obvious errors. The only advice I can give you
at this moment is to 'var' scope all your internal variables. The 'var'
scope is local to a single method and thus the variables will not clash
with similarly named variables in the in other methods or the global
'variables' scope.
output="false">
<!--- Initialize local function variables. --->
<cfset var myarray = "">
You have confirmed that putting the uri
" http://catburg/qqarray.cfc?wsdl" into a browser return the expected
WSDL file, correct?
Guest
Mar 18, 2008 Mar 18, 2008
How can I call my simple wsdl in ASP. I would like to test it.
CFC I have only simple query.
select firstname from emp
thanks
Mar 20, 2008 Mar 20, 2008
I think it's at this point that I would thank Ian Skinner for his help, his patience and the skillful way in which he has explained the web service concepts. I would then end there.
Guest
Apr 09, 2008 Apr 09, 2008
how to make this webservice secure.
Documentation
