I have a flex application that is calling multiple ColdFusion services, this has been working for a long time but now all of a sudden it stopped working and I have no idea what is causing it.
Basically, I am sending 15 function calls to different services through the flex gateway. The first one executes and all the other ones send this error message
"java.sql.SQLException: This connection either has timed out or has been closed and has returned to its pool. You must re-acquire the connection. " See attached Charles screenshot
The coldfusion application is a very simple ORM application running some simple single parameter hibernate queries like below
remote Wayeo_Service.cfc.city_clerks[] function searchByID39(string q ) {
var hqlString = "";
var whereClause = "";
var params = {};
hqlString = hqlString & "FROM city_clerks";
if (len(arguments.q) gt 0){
whereClause = ListAppend(whereClause, " ID39_City LIKE '%#arguments.q#%'");
if (len(whereClause) gt 0){
hqlString = hqlString & " WHERE " & whereClause;
hqlString = hqlString & " ORDER BY CityClerkID asc";
return ormExecuteQuery(hqlString, false, params);
any solution found ?????
Been quite some time since I looked at a Flex issue, but have you tried checking "Maintain database connections" in the ColdFusion administrator DSN? You don't mention the CF version on the back end, but there was a Hotfix that addressed this for CF 2011 and CF 2016. Please see this thread: https://tracker.adobe.com/#/view/cf-4108519
