I was loading some new ARCs from edelweiss and the program froze. Closed out and tried to reopen- no bueno. Restarted the computer and tried again, nope. Uninstalled, restarted, reinstalled, restarted, tried to open, still didn't open... Would really like to read the new Debbie Macomber and I would like to use this instead of the evil Kindle... (I'm B&N) Help!!!
Start Digital Edition 3.0
Used Shortcut [Ctrl] + [Shift] +
Then authorize again.
Closed Digital Edition. Rename the My Digital Edition folder and then open again. Now try to download your eBook.
That didn't work. Downladed 3.0 & it opens but won't let you open any books. Tried re-downloading books but it won't take the authorization, even though I'm logged in. I get activation server error code: E_ADEPT_INTERNAL for previously downloaded or Error! Check Activation. for new downloads...
OMG! It worked! Send me your email so I can send you a starbucks card. Thanks!!!
You are welcome. Thanks but i need nothing for my help
I have the same problem and your solution didn't work for me. Do you have any other suggestions?
What happend exactly when try the solution steps?
I was able to re-authorize by using your suggestion:Shortcut [Ctrl] + [Shift] +
Try this. Closed Digital Edition. Rename My Digital Edition folder under your Documents and then start again.
Ok, I renamed the folder. When I went to open it again the message said there was a newer version available and then it shut down. When I tried opening it again, it froze.
Has you install the update?
No, I didn't get the change before it shut down. I then tried to open it again and choose not to update. It also shut down right away. Should I update it when asked?
When its not work, when ignore try to install the update.
As soon as I click on the update option, it shuts down.
Uninstall installed version and install again with this: Herunterladen | Adobe Digital Editions
Still didn't work
You can not download the 4.5 Version?
I was able to download ADE 4.5 and I installed it. When I tried to open a book with it, it froze again.
Then try with 3.0: Adobe Digital Editions downloads
I've tried the ADE 3.0 also with the same response. It opens and then it is non-responsive (same as 4.5). I have to use the Task Manager to shut it down.
In this case the last solution is create a new local user acount Create a local user account in Windows 10 - Windows Help - and try this for Digital Edition.
Do you mean I should get Windows 10?
sorry copy the wrong link...right link are: Create a user account - Windows Help
Well your last solution worked as far as being able to open ADE in a new user account. I was able to download 2 books and get them onto my Nook. ADE still doesn't work under my original user account. It's a bit annoying to have to switch users (back and forth) but I'm happy that I at least can view the books. Please let me know If you have any other solutions to join these accounts.
Thank you very much for all your time helping me.
