This is currently the final function in a script I have that finds empty rows in a document and deletes them. But in this instance, I don't want to delete them. I want to change the max and min row height limits of these empty rows.
function deleteEmptyRows (rows) {
var i, count = rows.length, row;
for (i = 0; i < count; i += 1) {
row = rows;
if (rowIsEmpty (row) === true) {
row.Delete ();
I've got the cell dimension that I want to apply by running the below which gave me "371542". I thought I could just replace row.Delete (): with row.RowMaxHeight="371542"; but this doesn't do anything. Could anyone point me in the right direction please?
var doc = app.ActiveDoc;
var pgf = doc.TextSelection.beg.obj;
var cell = pgf.InTextObj;
var row = cell.CellRow;
alert (row.RowMinHeight);
Cheers
Chris
Thanks for sending me the doc.
I found the problem:
RowMinHeight was higher than RowMaxHeight :760213
So you just have to add in my example above:
fRows.RowMinHeight=371542;
fRows.RowMaxHeight=371542;
Hi Chris,
this should work, but without quotation marks: row.RowMaxHeight=371542
Hi Klaus,
Unfortunately not, I've tried with and without quotation marks and still nothing.
Chris
Hi Chris,
I've just tested this and it works:
I have created a table, selected it and started this little script:
var gDoc = app.ActiveDoc ;
var oTabSelected = gDoc.SelectedTbl;
var myRow = oTabSelected.FirstRowInTbl;
myRow.RowMaxHeight=371542;
I just copied and pasted this out and tried it over one of the tables in my document and it does'nt do anything. I get "Result: 371542" in the console and thats all. Could it be something to do with the formatting of the table?
Just try it first with an empty new table to make sure it works in general.
It works perfectly with new doc and new table. It must be something further back in the script that’s messing it up.
But if it was something further back then the delete command wouldn’t work in the first instance, but it does!
Would it help to see more of the script?
Chris
Hi Chris ,
I've just extended the script. Just compare it with your script.
var AllRows = [];
while (myRow.ObjectValid())
AllRows.push(myRow);
myRow = myRow.NextRowInTbl;
MinimizeRows(AllRows);
function MinimizeRows(fRows)
for (var i = 0; i < fRows.length; i++)
I guess, it has something to do with your document.
Is there a chance, that you send parts of your document to me via PN so I can test that?
That's done it!
Thanks a lot
Chris
