I recently changed from Win 8.1 to Win 10. I can no longer transfer books from Overdrive to ADE. They are both authorized the same. Any suggestions?
Try this: right click on digital edition and run as admin....
Sorry, that didn't work either. I used to be able to check out and download a book in Overdrive and it would automatically go to ADE and download to Nook. It will no longer do this. ??? Thanks
Nanaky, Sorry that didn't work either. I used to be able to download a book in Overdrive and it would automatically download to ADE then to the Nook. It doesn't do that anymore. What now??? Thanks
Have you check the Defould Programm for ePub files?
How do I do this? Check what?
Do used Windows or Macintosh?
Windows 10
Nanaky, Adobe Digital Editions is not listed on Default Programs. Overdrive is, but not ADE. ADE is installed and authorized on the computer.
RIght click on a eBook. Choose Settings. Then click on choose by programm and choose C:\Programme(x86)\adobe\Digital Edition Version\Digital Edition.exe.
Then should work
Nanaky, where do I rt click on an ebook? I have tried both ADE and Overdrive and neither has settings listed.
In you File Explorer. Choose a eBook File. Then rightclick to the file with your mouse.
I found file explorer>ebook>rt. clicked >still no settings listed.
o.O What points was display?
open, open with, share with, Norton Internet Security, restore previous versions, send to, cut, copy, create shortcut, delete, rename properties...
i
Then used the point properties.
File explorer>ebook>right click>properties>NO: c/programme (x86) ADE Version/Digital Edition.exe. Remember I am using Windows 10. What now?
Its work the same way also with Windows 10. Its a general Windows Process. On which point you have a problem?
When in default program, associate program with protocol etc, acsm>change; ADE is not a listed app although I can open it as app.
You should over choose ad a addition program. This not work?
