Greetings (I know this looks like my first post but I was
pretty active under another identity a couple of years ago).
I have RoboHelp HTML Help 6. I can happily add baggage files
(either directly from the Baggage Files folder in the Project tree,
or by adding a hyperlink in a topic) - UNLESS the filename is
HowTo.pdf. There isn't a problem with the file - if I copy it and
give it a different name, it gets added to Baggage Files. There
isn't a problem with the project either - I have the same problem
with a brand new project.
Despite the file not being listed under Baggage Files, the
resulting help file incorporates the required file. But the file is
included in the Unused Files report, and excluded from the Used
Files report.
Is this a 'reserved' filename that isn't supposed to be used?
Or is there another explanation?
Cheers
Simon
