Release all compound paths at the same time?
Jul 20, 2010 Jul 20, 2010
Platform: PC/Windows XP SP2
Adobe: Illustrator CS3 (13.0.2)
Is it possible to release all compound paths in an illustration at the same time (and if so - how)?
I receive drawings from engineering in either PDF or CGM format, which I edit in Illustrator and save as AI. I have to release compound paths in order to delete specific parts of the drawing.
This isn't difficult, but it is very time-consuming because the CGM(or PDF)-to-Illustrator conversion results in quite a few compound paths.
Thanks - I appreciate your help,
Dan
26.9K
Adobe
Guest
Select all, go to Object>Compound Path>Release.
Sorry -- I forgot to mention that I tried that; some of the compound paths were released but there were still quite a few that weren't...
Guest
Hmm...That's always worked for me. Are the ones that aren't getting released part of a clipping mask, or locked, or on a different layer, etc?
None of the above... I'll spend some time to see if I can figure out what the un-released paths have in common & repost if I figure it out. Thanks - I really appreciate you replying so quickly.
Advisor ,
Are they all compound paths or are some of them compound shapes?
Try release/expand compound shape?
Aug 13, 2010 Aug 13, 2010
Hi jesseham,
Yeah, they are all compound paths. If I ever resolve this, I'll leave a post. Thanks,
Dan
Are they grouped?
Oct 16, 2012 Oct 16, 2012
Did you ever figure out how to release all compound paths at once? I tried the Select All, Object, Compound Path, Release. After I did this 3 times, the 4th time Release was grayed out, so I couldn't select it. It was helpful but still left my PDF-converted-to-AI drawing with "connected" entities. There seems to be a difference between selecting via a window crossing vs. selecting via clicking. I am still unable to select the entities I want to edit without including other unwanted entities. Anyone?
Guest
Feb 25, 2014 Feb 25, 2014
SOUNDS LIKE THOSE OBJECTS ARE GROUPED, PRESS CTRL-SHIFT-G
Aug 17, 2014 Aug 17, 2014
thanks for the help, no need to shout.
Nov 19, 2015 Nov 19, 2015
Use this script
var doc=activeDocument;
var sel = doc.selection;
var len = sel.length;
while(len--)
   if(sel[len].typename ==="CompoundPathItem"){
  sel[len].selected=false;
alert("Only non-compound items are selected.");
Source: Scripting Illustrator: Select Compound Paths only
