Hi everyone!
I need to use terminal command using javascript on extendscript.
But, i will automate the script on macintosh and windows operating systems.
Is it possible to use both in same code?
For Example, i will automate the pdffonts names in the pdf files. so, i use the command on mac "pdffonts /Users/user/Desktop/fontlist/pdf" that gives the pdf font names. That works on manually. Is it possible to use code for mac and windows on extendscript toolkit? or separately give a code!
Peter.
I am not sure how this works on the Mac, but with Windows, you can have your commands in a batch file and then execute that with ExtendScript. For example, here is a script that creates a batch file and then executes it:
var bat = File ("~\\temp.bat");
bat.open ("w");
bat.writeln ('start Notepad.exe "C:\\DATA\\Scripts\\results.log"');
bat.writeln ('quit');
bat.close ();
bat.execute (); // This is what runs the batch file (like a double-click on it in Windows Explorer).
You can detect the OS that
...Copy link to clipboard
bat.open ("w");
bat.close ();
You can detect the OS that the script is running on by using $.os. On my system this
alert ($.os);
displays "Windows/7/64 6.1 Service Pack 1 (32-bit emulation)". -Rick
Thank you very much for your reply...
Hi John, If this solved your problem, please mark my answer correct. Thank you very much. -Rick
hi,
your answer works on windows perfectly.
Thank you.
