I need to downgrade to an older version of flash because my machine only has a 2.08ghz processor and the current version requires 2.33ghz. Every time I try to install an older version, the program kindly informs me that I am installing an outdated version, and redirects me to their website without the option to continue. Why is this??? Is there any way around it? Also, does anyone know the latest version my machine will support?
Hi thomasl75502018,
2.33ghz has been the recommended processor ever since Flash Player 10.2. Flash Player 10.2 is many years old, has not been updated with any security fixes, and will most likely be blocked by all major browsers since major browsers are known to block older versions of Flash Player.
Flash Player should still work fine on your system, however, depending on what content you're viewing, or games being played, you may experience performance issues. If you're not experiencing performance issues, there's no reason to downgrade to an older, unsafe version of Flash Player.
Maria
Maria, I absolutely need to downgrade, I can view exactly zero video content on my pc, I am 100% sure the incompatible flash is the cause of the trouble.
Latest version of firefox running on 32bit windows xp, 2.08ghz processor 960mb ram and I don't believe the machine is x86 compatible.
It seems I missed you're reply. I apologize. If you're Windows XP is 32-bit then it's x86-compatible. Previous versions of Flash Player are posted at Archived Adobe Flash Player versions. You'll first need to run the uninstaller, posted at Uninstall Flash Player | Windows‌, before you can downgrace. I really don't recommend installing Flash Player 10.2. Not only is it extremely outdated and doesn't have any security fixes, but most modern browsers will block it due to it being so old, and unsecure.
Google integrateds Flash Player in Chrome and updates are released via Chrome updates. To revert to an older version of Flash Player in Chrome would require downgrading your version of chrome. I'm not aware of a way to downgrade Chrome. I've actually looked for older versions of Chrome and have not found the link to them.
Maria
Ä° think i have the same issue . But my laptop is overheating since September or August ... around there . Ä° want to downgrade . How can a healthy laptop can overheat while its being used by extra fans and dust cleaning regularly ? Plus only thing im using on my laptop is google chrome no viruses no hardware issues just got checked only thing changed is Adobe Flash Player version . Ä° would be appreciated if you could help me . Ä°t is clearly i am having problems with Adobe Flash Player 19
Thank you sooooooooooooo much . Ä° can quit using chrome and start using another browser
Hi orkunç44996145,
While we do post previous version of Flash it's not recommended to install older versions unless absolutely necessary. If you're going to use a different browser, I recommend installing the latest version (from https://get.adobe.com/flashplayer) before downgrading to an older unsecure version. It's also possible that the browser will block the older version.
Maria
