When I tried now to open one of my digital books to read I get the message of "Activation Server Error" "Code: E_ACT_NOT_READY". Digital Editions encountered an error on the activation server. And they say I must click the "Try again" button. But that button is not working.
I upgrade my laptop from windows 8.1 to windows 10. I also try to deactivate the activation but the message is the same. "Activation Server Error"
Can I please get support on this.
Start Digital Edition.
Press ctrl + shift + d and accept that want deauthorize.
Then enter your Logindata under help > authorize computer.
It 's not working. I already try this action that you suggested. I need another support please.
On which point the solution not work?
When I tried to open a digital edition I get the message: " Activation Server Error. Code: E_ACT-NOT-READY" "Digital Editions encountered an error on the activation server". The try again button also not working. Then I tried to de-authorize the activation after I looked that I am authorize to read the editions. The message that I get for the de-activation said: "Unable to Erase Authorization. Please try after some time. Now this some time stretch over three days.
I were able to read the digital editions with my laptop with windows 8.1. I upgrade now to windows 10 and Adobe also sent me a upgrade which I did (4.5). That was about two to three weeks ago when I did the upgrade. And it is now that I experience the problem with the authorization.
On my PC which is still windows XP I don't have that problem. I can still read the editions.
Try this:
Hi Nanaky, Thx for support.
I follow your instructions up to point 8. When I right click there the option for delete is not highlighted so I cannot delete.
Any other suggestions?
Hilda
To remove a key you must have the pemissions for this. Do you login as Admin?
No, now you must give me more details because I did not this before
Hilda
Then try to login as Admin and repeat the steps. Then its should work.
Hi Nanaky. thx for the support. I appreciate it very much. I try your instructions again and it works.
Lovely day for you.
Hilda
You are welcome.
