Hi GShep,
Disclaimer #1: I have no way of knowing your experience
level with live recording or public speaking, so please overlook it
if I say something real basic to an "old audio pro".
Disclaimer #2: I have never had a problem with bad audio, so
I am not an expert on how to fix it. That said, I've made a lot of
good audio clips, so maybe I've been lucky for years, or maybe I
have something to offer (or maybe I am just so tone-deaf that I am
beyond surgery).
To start, have you tried to "fix" it before recording, by
setting your audio "level"? Each time Captivate is started, before
audio recording you are given the opportunity to "set" your voice
recording level. Try speaking distinctly and forcefully (not loud,
but with authority) while you are doing that thing with "
I am now setting my recording level in Adobe Captivate" (don't
remember the exact wording, but you know ... (?)
If that doesn't work, shut down Captivate, restart, and try
again, this time speaking very softly, but again, clearly and
distinctly - enunciation is important to any speaker. It is a
"season to taste" thing, but in any case you must be in a
disturbance-free environment, and you must be willing to experiment
with your equipment and how it (and you) interact with Captivate's
audio engine.
Another often overlooked item is the microphone - the type
and its placement. If you are using a desktop microphone, get rid
of it and go buy an inexpensive headset "boom" setup. A desktop mic
will be placed differently (relative to your lips) every time you
use it, and often it will change
during your use. A recipe for bad audio, because the
microphone-to-audio-source becomes a lot like hitting a moving
target.
A headset with a boom mic is not just a better way, it is the
only way, unless you are already a voice-over professional
and are familiar with the physical requirements and hardware of a
seasoned radio speaker. Make a point of placing the headset so that
the boom mic is the width of your little finger above the line of
your lips, and above the corner, not the center of your mouth
(either right or left corner). That by itself will eliminate much
of the "breathing" noise that forces the recording amplitude up,
and is heard in the completed recording as "noise".
Obviously I'm throwing out a lot of disparate suggestions,
but I hope that one or more of them is helpful.
best wishes~
Larry
