Hi
I have tried in the following way. But it is not working with adobe media server 5.01 extended! I am using media encoder 3.2
These are the steps you need to follow :
1. Download the Add-in from here :
www.adobe.com/go/learn_fms_authaddin_en.
2. Run the installer on the machine where FMS is installed. For windows run the msi. For linux untar the file and run the installSAA script.
3. The add-in installs the Server Access Adapter (under root_install/modules/access) and the Flash Media Encoder User Management utility (under root_install/conf).
4. Navigate to root_install/conf in the command prompt and run the following to add new user :
users add -u <username> -p <password>
5. Restart FMS.
Hope this helps. Let me know if you have any other queries.
