WebHelp
Mar 18, 2008 Mar 18, 2008
HI all,
I am completly new to RoboHelp . I have help system for my company which i want to upgrade using Robohelp. So i imported the help files in html format and then tried to generate the primary layout but it doesnt open the existing table of contents . I want it to use the toc of my help system. I have used HDK to bulit the help system, which gives me an option to build the help system in HTML format useful for robohelp. When building in robohelp it doesnt use the toc that i have imported into the project . Can anyone please help me ?
Thank you
307
Mar 19, 2008 Mar 19, 2008
Hi sindujasundara and welcome to the RH community.
Can you tell us what your primary layout is (e.g. Microsoft HTML Help, Webhelp) as this information is critical to solving your problem. Also can you tell us what does appear in the TOC? Does anything appear or something you weren't expecting? Did you generate a TOC? If so, how? Finally can you tell us what version of RoboHelp you are using.
Sorry for all the questions
Sorry. I just reread the title of your post. You are producing Webhelp as your primary layout. One further question then. Are you looking at the generated output or the published output. Both can be different. The generated output is the compiled output. The published output is the output published to the "live" location from where your users can access it.
To avoid confusion I would not refer to the generated output as being the compiled output. Only HTML help in a CHM file is compiled.
WebHelp starts with source files and an output is then generated locally. It can optionally then be published by the author to a server. Where the author does not publish, then the developers will take the generated output and publish it themselves. At no point do the files go through a compiler such as that used to create winhelp or CHM files.
The generated and published outputs should not be much different although sometimes things will be added to the published version or left in when they should have been stripped out. However, I think going into that in this thread will confuse matters.
Does the TOC appear correctly in the RH Project Manager?
Are you seeing a TOC tab without content in the output or are you not seeing a TOC tab at all?
What version of RH are you using?
The CHM junky takes the comments of the WebHelp junky on board
RoboHelp Documentation
Download Adobe RoboHelp
