Has anyone had this issue? Does anyone know what is causing the error?
This has been going on for the past couple days now. There are a number of forums posts about this with no fix from Adobe yet.
Re: Indesign: evented I/O for v8 javascript has stopped working
I've seen this when indesign or photoshop is open and problem started when updating the Adobe Creative Cloud app. This is affecting hundreds of users spread across multiple companies I manage.
I've managed to stop the error by doing the following
renamed node.exe to node.bak in the following locations:
C:\Progr
...Copy link to clipboard
I have the same problem.
Does anyone have a solution ?
Thank you
Just happened to me this morning as well once I opened up InDesign. Hopefully they will have it fixed soon.
Same issue here also (InDesign) after Creative Cloud was updated today.
Might have found a temporary solution.
Open Task Manager, Check box for "Show processes for all users" and end process for "AdobeUpdateService.exe"
Ending AdobeUpdateService.exe doesn't work for me. Seems like CCLibrary.exe keeps re-opening and throwing this error constantly as long as InDesign is open.
Ending AdobeUpdateService.exe doesn't work for me too...
What I have find out is just a temporary solution.
- msconfig - turn off all Adobe services
- restart
- rename - C:\Program Files (x86)\Adobe\Adobe Creative Cloud -> Adobe Creative Cloud_old
- msconfig - turn all Adobe services
- restart
You don't have access to CC, but you can work with apps. For some time I assume.
I have started having the same problem the last 2 days as well. Open any Creative Cloud program and the error window continually pops up.
I am having the same issue after Creative Cloud updated.
Photoshop is now also being effected by this issue.
None of the temporary fixes seem to have worked for me either
Hi All,
I apologize for the inconvenience caused. Could you please confirm whether the issue is specific to any one particular Adobe Application or all of them.
Anupriya Khare
C:\Program Files\Adobe\Adobe Photoshop CC 2015\
C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\
C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\
Waiting for appropriate fix from Adobe as this is a wide-spread issue.
Thank you, that worked for me.
This fixed my issue as well. however the file was not located in program files\ folder but was in the both x86 folders.
My issue is basically all programs associated with Creative Cloud - Indesign, Photoshop, Illustrator, Muse etc.
It started occurring after the Creative Cloud application updated this morning.
Please try the steps mentioned in Evented I/O for V8 JavaScript, is it safe?
Hope this will help you.
Hi Anupriya,
You are Adobe staff. Do you know when Adobe will be releasing a patch for this issue?
Well I have already escalated this issue to the concerned team. Will update here soon with the solution.
I did the instructions in this thread Evented I/O for V8 JavaScript, is it safe?
Seems to have worked! Thanks.
What's the estimated time for the update?
Jaakko
I'm still getting this error. I updated CC on Tuesday. Followed these steps:
1. Go to here and download process explorer: https://technet.microsoft.com/en-us/sysinternals/processexplorer.aspx
2. You will get a .zip file that you need to extract to a normal windows folder -> Right click extract
3. Run the file procexp.exe
4. Accept the license terms
5. Once the Process Explorer is running you can select from the list a process called: node.exe (green icon)
6. right click node.exe and select Suspend
But after a few hours of working in either Photoshop, InDesign or Illustrator - I'll get the error again (less frequently though), and if I reboot I get the error message every 20secs-3mins, until I follow the steps again.
For me it worked this way. Hopefully not only temporarily.
I was told that it´s a windows problem ?! ... I´m also using CC2015 on a Win 7 machine.
Well that workaround worked when I first had the problem but today when Adobe CC updated, the problem returned and that fix NO LONGER works!
Adobe can you please provide a fix?
I just this again today and the old suggested fox doesn't resolve it. Are we going to see a fix sometime soon?
It's back and worse than ever, and nothing fixes it now. I've uninstalled, reinstalled, updated, everything.
