I am hoping I can get a response to my Tools menu problem on
this forum, because the post to the RSC forum has not (yet)
resulted in a satisfactory solution. Although the problem is
associated with projects in RSC (and, more specifically,
with having added files via RSC instead of during the normal course
of work in RH), the problem occurs in RH HTML itself, and this is
the first place I looked for an answer.
Background: My team is single-sourcing two help projects (for
two different products) that share about 80% of the same topics.
And those shared topics are tagged up with conditional build tags
to suit each project. At first we used the same project files for
the two projects. But we couldn't adjust the TOC or Index. We also
had trouble with the title and file name of the compiled help
(which are saved in the HHP file).
So our solution was to create separate project files based on
the original ones. I duplicated all of the ProjectName.* files and
adjusted them in Notepad. Then I added them using RSC's Add Files
command. When I work with the "new" project, everything works
great,
except the Tools menu that doesn't drop down. (It doesn't
drop down in the original project now, either!)
I'm no techie, but I am interested in what is actually
happening here. Seems like somehow RH HTML is not getting the right
signals about what to display on the Tools menu. I'm thinking
there's got to be some under-the-hood tweaking that can be done to
activate that Tools menu -- an INI file setting or something?
I usually get really good help from the experienced users on
this forum.
Therefore I have high hopes for a solution that does
not involve (1) going back to sharing the same project files
(ProjectName.*) for two different projects or (2) separating the
projects into different locations in RSC, which would be
really complicated considering that the two software
products we're documenting share code and sometimes implement the
same functionality but at different points in time.
