onMissingTemplate function in Application.cfc
Nov 12, 2015 Nov 12, 2015
Hello, all,
I'm trying to implement a process for missing templates, so that the user will never see a CF error message for missing pages.
The problem is that even though it will trigger my onError function, it's still outputting CF errors at the bottom of the page.
Here is my onMissingTemplate() function:
<cffunction name="onMissingTemplate" returntype="boolean" output="false" >
    <cfargument name="template" type="string" required="true" />
    <cfset this.onRequestStart(arguments.template) />
    <cfset this.onRequest(arguments.template) />
    <cfreturn true />
</cffunction>
How can I get this to stop processing after displaying the onError page, so that it won't show the CF error mesages?
V/r,
^_^
707
Advocate , Nov 30, 2015 Nov 30, 2015
From what I can tell, your onMissingTemplate trap is probably working but your code within the event is retriggering the same error. I'm not sure your goal. I usually create an error.cfm template and simply include that module:
    <cfinclude template="error.cfm" />
    <cfabort />
</cffunction>
I'm not 100% certain if the cfabort call is required but it does
Nov 16, 2015 Nov 16, 2015
I'll add a screencap of what I'm referring to.  Everything below the logo should not be displaying.
Guide ,
Nov 27, 2015 Nov 27, 2015
WolfShade‌, what is in your onRequest() method?  If you pass the nonexistent template as an argument of onRequest(), but don't force navigation to a different page, it would still throw an error.  Do you have a FileExists() check in onRequest() to verify the template exists prior to including it?
-Carl V.
Hi, Carl Von Stetten‌!
My onRequest() method is bare-bones:
<cffunction name="onRequest" returntype="void">
  <cfargument name="thePage" type="string" required="true" />
  <cfinclude template="#arguments.thePage#" />
</cffunction>
The onError() method is triggered, which redirects to my errors.cfm page, and it _should_ stop processing after displaying errors.cfm.
I've seen several examples online for onRequest() and onError(), and I've never seen one include a FileExists() conditional.  Is that common??
V/r,
^_^
Advocate ,
    <cfabort />
</cffunction>
I'm not 100% certain if the cfabort call is required but it does not seem to hurt. <cfreturn false /> probably does the same thing.
<cfreturn false /> did not prevent the CF error message from appearing, but <cfabort> did.  I'm a bit leery to use <cfabort>, because I don't know if that will prevent other things from happening; however, at this point, I'm willing to give it a shot in production.
Thanks, Steve Sommers‌!
V/r,
^_^
Advocate ,
I try to limit my use of cfabort but for something like this I would use it (obviously since that was my example). If you have an onRequestEnd (or whatever it's named), cfabort does prevent it from being called. I found this out the hard way when my onRequestStart was allocating some memory and my onRequestEnd was releasing it -- upon several cfabort calls, I was out of memory and this was a tricky one to find.
Documentation
