First a little history;
I had LR5 on my PC, I then got a new IMac. I then moved my photos from the PC to an external hard drive (not using Lightroom, probably a mistake) I then installed LR5 on my IMac. All was fine, I reimported some of the photos using LR5 no problem. Last spring I bought LR and PS CC for the 10 bucks a month, but I kept LR5 on the IMac just for safety sake.
My problem;
I find I can't import photos from my external hard drive using the LR CC, (I have the latest update) I get an error message that says "Lightroom is unable to import the file". If I open LR5 I CAN import the files, I save the file to a folder, but to use LRCC I must then reimport from the folder it was saved in with LR5.
It's all doable but with a big hassle.
Any Ideas?
Hi Dennis Hoyne,
Greetings.
When you open the import window in LR, make sure you select a source and a destination.
Do you nee any error message, if possible could you post a screen shot of LR import error message.
Regards
Rohit
You should not be importing things on the Mac that were already in LR on the PC.
When you move things from a PC to a Mac, you copy your photos using the same relative folder structure AND copy your catalog over, then open the catalog in LR on the Mac and relink the top-level folders in the LR catalog to their new locations on the Mac.
