Presenter 11, test version on Windows 7
I looked at the help-pdf but. I'm not able to change the properties of any annotations in the timeline nor can I delete annotations. When the field for annotations is marked I can see the annotation as a small black mark but there is no way to "strech" it in the timeline below.
Is it because of the test-version?
Thanks in advance
Andreas
Hi Andreas,
I took a look at your project.I am able to select annotations and modify their properties.
Following steps might help you .
1. Open the project in Presenter Video Express.
2. Click on the Annotations button (5th one from bottom left)
3. Go to the frame where you have annotation ( In your project, annotation is at 4.08. Seek to any frame between 4.08 to 4.12 ).
4. Click on the ellipse that you have added on the presentation.
5. Now you can see a rectangular (bounding) box drawn around the el
...Copy link to clipboard
Andreas,
I suppose you are referring to the Presenter Video Express tool shipped along with Presenter.
The trial (test) version you are using has all the features of the full version.
It should be possible for you to add annotations anywhere on the timeline and anywhere on a frame. Once you add a shape from the annotation panel, you should be able to re-position it on the frame and also resize it or delete it using the DEL key. You should also be able to stretch/reduce the duration for which the annotation - select the annotation, and then elongate/reduce the yellow band on the timeline as desired. Please check out the last tutorial on the annotations feature at Adobe KnowHow
Regards
Ramesh
Hello Ramesh,
many thanks for your answer. Yes I'm referring to Video Express.:
Before posting here I went already to mentioned tutorial at the helpdesk and after tried to use the annotations in the described way- doesn't work.
I can add the annotations and reposition but I cannot stretch it (it doesn't turn yellow, I cannot select it). The DEL - keyneither works, because I cannot select the annotation. (That's what I think is the reason)
Greetings
Andreas
Hi Andreas,
Annotation should get selected by clicking on created annotation drawn on the frame. Once the annotation is selected, its properties can be modified.
As you are unable to select the annotation, can you please share the sample project folder with us, so that we can analyze the project?
You can locate it inside the Presenter Video Projects folder. You can zip it and share via Dropbox to PVX-ProductionSupport@adobe.com.
Manasa.
Hello Manasa,
I only could share it in this moment.
I zipped the whole folder, hope this is correct.
The projects name is "Intro ensayo 2"
Thanks in advance
Andreas
Hi Andreas,
5. Now you can see a rectangular (bounding) box drawn around the ellipse. Once the annotation is selected you can stretch it using handles or you can change its properties.
Here is the screenshot when an annotation is selected
Let me know if this worked.
Manasa.
Hello Manasa,
many many thanks. I always tried to select it in the timeline below.
Works perfectly, thank you so much
Greetings
Andreas
Hello,
you helped me si much some days ago. Thanks again.
May I ask you to look to a problem that I cannot solve with an issue with my webcam.
It´s vital for me that I can use the cam correctly, otherwise I have to return it.
The thread is
Thanks in advance
Andreas
