2 Replies Latest reply on Dec 1, 2015 8:21 AM by ReidFilms
    Split clips in multi-track view while playing
      Why can't you split clips in Audition CC while playing the audio like you could in older versions of Audition. As a radio producer i need to be clipping audio very quick while I'm listening through the audio. You can select a section of a clip and split-delete while playing, why not a simple split?
      Also when you do select a part of a clip and delete (still in multi-rack mode) why does audition then select both end of the clip remaining automatically? Usually when you do this you are tightening up gaps so when you go to grab the right side split audio to move in the left side moves as well. I know its a simple click away and re-selct process, but gets annoying whe you are doing a lot of them and i can see no reason why you would want to default to having them both selected.
