quote:
Originally posted by: Captiv8r
hi RodmanV
Normally the installation doesn't prompt for a serial. It isn't until you run it for the first time. Once you do that, you should see a screen providing two choices.
1. Enter a serial number
or
2. Continue in Trial mode
Sometimes we see folks report having tried the "trial mode" only to have the application return to the screen I mentioned and trial mode is no longer available. Is this possibly the case here?
Cheers... Rick
quote:
Originally posted by: Peter Grainge
What operating system?
Wondered if you had missed the post about Windows 2000. Nobody has reported any problems with Vista. As Rick indicated, you should see two options and one is to continue in trial mode when no serial number is required.
You are seeing that option and clicking it but you then return to that screen. Could your firewall or AV program be blocking it?
Is it possible the trial version has been installed before?
You do have admin rights?
