get values from Javascript
Contributor ,
Dec 01, 2015 Dec 01, 2015
I'm trying to pass an identification name or number from Javascript so I can use one SWF to pass data based on the page.
This works with ActionScript 2 but can't figure out why it does not with ActionScript 3:
<script type="text/javascript">
tPageID = 145;
function getPageID() {
     return tPageID;
</script>
Flash:
import flash.external.ExternalInterface;
var pageID = ExternalInterface.call("getPageID");
It seems it's always NULL with AS3.
Thanks for your help,
cpliu
ActionScript
808
Community Expert , Dec 01, 2015 Dec 01, 2015
then your embedding html may be the problem.  change test2.swf to match your swf and fix the width/height values and try:
<!DOCTYPE html>
<html>
    <head>
        <meta charset="UTF-8">
        <title>test2</title>
        <style type="text/css" media="screen">
        html, body { height:100%; background-color: #ffffff;}
        body { margin:0; padding:0; overflow:hidden; }
        #flashContent { width:100%; height:100%; }
        </style>
tPageID = 145;
fu
put the script tags in the head tags so that executes before your swf is embedded.
Contributor ,
Yes, the Javascript was located before the code to load SWF. This is on SharePoint. I even move the Javascript to a different web part ahead of the script loading the SWF but it didn't make any difference.
If I try to pass the value to a text field, it always gets the following error; I assume this was caused by the null data:
TypeError: Error #2007: Parameter text must be non-null.
  at flash.text::TextField/set text()
  at AS_n_JS_AS3_fla::MainTimeline/frame1()
<!DOCTYPE html>
<html>
    <head>
        </style>
tPageID = 145;
     return tPageID;
</script>
    </head>
    <body>
        <div id="flashContent">
            <object type="application/x-shockwave-flash" data="test2.swf" width="550" height="400" id="test2" style="float: none; vertical-align:middle">
                <param name="movie" value="test2.swf" />
                <param name="quality" value="high" />
                <param name="bgcolor" value="#ffffff" />
                <param name="play" value="true" />
                <param name="loop" value="true" />
                <param name="wmode" value="window" />
                <param name="scale" value="showall" />
                <param name="menu" value="true" />
                <param name="devicefont" value="false" />
                <param name="salign" value="" />
                <param name="allowScriptAccess" value="sameDomain" />
                <a href="http://www.adobe.com/go/getflash">
                    <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
                </a>
            </object>
        </div>
    </body>
</html>
Contributor ,
I then tested loading the SWF and included the Javascript in header with Dreamweaver. It works. I then compare the code from DW, and converted it a format acceptable to SharePoint then it works. THANKS for your help.
I don't know why, but the 2nd line below is the old one and if I switch to that line, SWF in AS3 does not pick up the data from Javascript. Maybe something wrong with the codebase=.... being not used anymore?
       document.write("<object id='FlashModule' classid='clsid:D27CDB6E-AE6D-11cf-96B8-444553540000' width='550' height='400'>")
        //document.write("<object classid='clsid:d27cdb6e-ae6d-11cf-96b8-444553540000' codebase='http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0' width='550' height='400' id='freeflash_final' align='middle'>");
only some swf embedding methods are compatible with externalinterface.  using an incompatible method causes externalinterface to fail.
