Hi, When i try to activate my authorization key I have the msg : e-auth_not_ready
Can you help ?
Hi Laurent,
Your authorization file is damaged and it needs to be cleared out.
You need to delete out a few registry keys to clear the activation for ADE. You must have administration authority.
On Windows it can be found here:
Open Windows Registry by using the command prompt and typing 'regedit' or by opening the start menu and searching for 'regedit'.
Search for the following folder:
HKEY_CURRENT_USER\Software\Adobe\Adept\Activation
The 'Activation' folder can be entirely deleted.
On Mac it can be found here:
In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
~/Library/Application Support/Adobe/Digital Editions/
Delete every file within the 'Digital Editions' folder.
Restart ADE and it should be deactivated at this point. You should be good to sign back in.
